OlivetIsa 19 Posted October 30, 2020 Posted October 30, 2020 Hi everyone!! I’m able to upload on my server movie trailers in order to have them in French by inserting them in the same folder as the movie, I tried the same thing with TV Show but it doesn’t work as Emby think it’s a new episode. Here is a screenshot. Thanks in advance !!
Solution GrimReaper 4861 Posted October 30, 2020 Solution Posted October 30, 2020 (edited) Make a subfolder named "Trailers" under your series folder, put the trailer in there and rescan your library. Cheers. Edit: It doesn't even have to follow same naming convention as movie trailers with no subfolder, all my trailers are named "tvshow-trailer.xyz" and placed in respective folders. Edited October 30, 2020 by GrimReaper76 1
OlivetIsa 19 Posted October 30, 2020 Author Posted October 30, 2020 Thanks Grimreaper76 I just tested your method and it works perfectly
Happy2Play 9802 Posted October 30, 2020 Posted October 30, 2020 Currently trailers folder is the only method that works with TV Shows. @Luke should both methods work?
