TwistedHe 0 Posted October 30, 2020 Posted October 30, 2020 Hello The Emby icon is greyed out on our Sony TV and will not start. Emby works on all our other devices, phones, tablets, Google Chrome etc, just not our main TV. Any idaes? log attached :0) Thanks Sam embyserver.txt
Carlo 4564 Posted October 30, 2020 Posted October 30, 2020 Hi, have you tried uninstalling then reinstalling the app?
TwistedHe 0 Posted October 30, 2020 Author Posted October 30, 2020 Do you mean on the TV, If so it doesn't have an app, I am opening the Music Photos Videos section on the built in TV menu and from their it lists the greyed out emby icon.
Carlo 4564 Posted October 30, 2020 Posted October 30, 2020 That sounds like a DLNA connection. I'd try restarting your Emby server and your TV itself.
TwistedHe 0 Posted October 30, 2020 Author Posted October 30, 2020 I have tried that loads of times :0) Could it be a firewall issue on the windows 10 Emby server?
Solution TwistedHe 0 Posted October 30, 2020 Author Solution Posted October 30, 2020 Well I seem to have fixed the issue by turning on UPnP on my router. Would that be the actual reason or just lucky timing?
Carlo 4564 Posted October 30, 2020 Posted October 30, 2020 Nope, sounds like the logical thing to do. Glad you got it working!
