Is there a way to have the Emby server search the internet for your full library’s metadata or do you have to do it manually for each title, movie or tv show?
PenkethBoy
on the home screen use the ... menu for the library and use the refresh option - will do the whole library
Ok I’ll give it a shot
Thanks
