justinrh 267 Posted October 30, 2020 Posted October 30, 2020 When Emby records live TV, does it have the ability to: 1) remove commercials? 2) convert the file to a different format? What is the default video format that it records to?
sross44 434 Posted October 30, 2020 Posted October 30, 2020 @justinrh I just started a pretty good sized post about this a few days ago. But the short version is not directly. You can set up a program like MCEBuddy to use ComSkip to delete the commercials. I believe it defaults to a .TS file extension. MCEBuddy can convert it to a lot of different extensions immediately after recording, so almost a seamless instance.
justinrh 267 Posted October 30, 2020 Author Posted October 30, 2020 Thanks @sross44 . I use MCEBuddy already. I was hoping Emby had commercial skipping built-in, like Plex does. I guess if I have to convert, might as well strip the commercials at the same time.
sross44 434 Posted November 1, 2020 Posted November 1, 2020 I hear you... I wish it did too! It’s one of the few things I prefer from Plex. But other than that, I absolutely love Emby.
