rodainas 191 Posted October 29, 2020 Posted October 29, 2020 Am trying to download subtitles using the plugin, the plugin gives me result when searching but it wont let me download them. I got this error on the log. I understand there is a limit to download but is me just trying to download a couple of times with no success, I cant be at the limit because the server has never downloaded any subtitle. *** Error Report *** Version: 4.5.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-48-generic (buildd@lcy01-amd64-010) (gcc version 9.3.0 (Ubuntu 9.3.0-10ubuntu2)) #52-Ubuntu SMP Thu Sep 10 10:58:49 UTC 2020 Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Common.Extensions.RateLimitExceededException: MediaBrowser.Common.Extensions.RateLimitExceededException: OpenSubtitles rate limit reached at OpenSubtitles.OpenSubtitleDownloader.SendRequestAsync(ReadOnlyMemory`1 request, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.Login(CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.GetSubtitlesInternal(String id, OpenSubtitleOptions options, CancellationToken cancellationToken) at MediaBrowser.Providers.Subtitles.SubtitleManager.DownloadSubtitles(Video video, String subtitleId, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Api.Subtitles.SubtitleService.Post(DownloadRemoteSubtitles request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: OpenSubtitles TargetSite: Void MoveNext()
Luke 42255 Posted October 29, 2020 Posted October 29, 2020 Hi, I believe the rate limit applies to all requests, and that includes searching. If you turned on automatic downloading in library settings, try turning that off, then wait a day and then try to do some manual downloads again.
rodainas 191 Posted October 29, 2020 Author Posted October 29, 2020 (edited) Thanks for the reply @Luke I have the automatic downloading disabled since 3 days ago. On the log i searched for the userrate limit error and it has 118 entries on the last hour, I tried a couple of times downloading with the error but am sure it wasnt 118 times trying. Edited October 29, 2020 by rodainas
Luke 42255 Posted October 29, 2020 Posted October 29, 2020 We'd have to look at examples in order to comment further. thanks.
rodainas 191 Posted October 29, 2020 Author Posted October 29, 2020 (edited) Update: Tried with another account, it is working. Thank you. Edited October 29, 2020 by rodainas
