cjlong45 17 Posted October 29, 2020 Posted October 29, 2020 Hi I'm having an issue I hope someone can solve So one of my HDD got unplugged and then reconnected but now emby is missing all my media related art even though all of the images are on the same HDD amongst the video files this has happened before and I had to manually change each movie etc can some one tell me if there is a way of emby finding it again and changing what it has been changed to and is there a way I can stop this from happening again Many thanks
Gilgamesh_48 1243 Posted October 29, 2020 Posted October 29, 2020 Well the first thing that come to mind is that you are using some flavor of Windows and when you reconnected the drive it got assigned a different letter and therefore the files are not where they used to be. You can use windows drive manager to get the letter(s) back the way they were if that is the problem. Other than that you might want to include logs from before and after the disconnect so the experts can look at it.
Luke 42238 Posted October 29, 2020 Posted October 29, 2020 Hi there @cjlong45 can you please go over an example? Thanks.
