GiGo 108 Posted October 28, 2020 Posted October 28, 2020 Just started using an old device to cast emby to my living room TV and notice there is no 'Quality' option for the stream, is this an oversight or not a option whilst casting? Was hoping I could use a device rather than having to use the other devices remote to change quality if necessary.
Luke 42244 Posted October 28, 2020 Posted October 28, 2020 Hi, it will be coming in future updates, but you can also set the Chromecast quality in the app's settings menu.
GiGo 108 Posted October 28, 2020 Author Posted October 28, 2020 25 minutes ago, Luke said: Hi, it will be coming in future updates, but you can also set the Chromecast quality in the app's settings menu. Thanks for the fast response, good to hear it will be included soon
