jasonmcroy 320 Posted July 26, 2014 Posted July 26, 2014 Hi all. Yesterday I decided to try and download Aeon Nox via the repo. I have had it installed for about a month and used it to download the Confluence skin. It worked fine then. When I tried to download Nox it went through the motions and showed the % of download up to 99%. It then acts like it's going to go to the next step and show me "add-on enabled" or something but that never happens. I waited for about 10 minutes in case it was just being slow. Nothing ever happened. I double check the Appearance section to make sure it didn't really download and just didn't give me the notification that it had. I restarted XBMC and tried again. Same deal. I tried to download MQ5 to see if it would do it. It did the same thing. I restarted my computer and tried again. Same thing is happening. I gave up last night and decided to try again this morning but the same thing is happening. I am attaching a log but I am not sure if it is the one you need. Let me know if it's not. http://pastebin.com/5RMWy18H -Jason
xnappo 1611 Posted July 26, 2014 Posted July 26, 2014 Hmm- I just tried an had no problem... I don't see anything suspicious in your log. xnappo
jasonmcroy 320 Posted July 26, 2014 Author Posted July 26, 2014 Interesting. Perhaps I will try to re-install and try again. Thanks for looking at this so fast! -Jason
xnappo 1611 Posted July 26, 2014 Posted July 26, 2014 Try right clicking or hitting 'c' and select 'Force refresh'. xnappo
jasonmcroy 320 Posted July 26, 2014 Author Posted July 26, 2014 (edited) I did try that. Since my last post I uninstalled XBMC completely and re-installed it. I installed the repo, installed Confluence via the repo and it worked but Aeon Nox still won't complete its download. I then tried MQ5 and it downloaded fine as well. It is fine with me for now as I am going to keep on playing with MQ5 today as I like it as well, just wish widgets would work with Video Nodes. Probably just a problem on my machine since you don't seem to be able to make it happen. No worries unless someone runs into same issue. :-) -Jason Edited July 26, 2014 by jasonmcroy
xnappo 1611 Posted July 26, 2014 Posted July 26, 2014 Okay - so that probably means I screwed up the Aeon Nox repo @@im85288 - I know you are working on other stuff... But can you take a quick look at how I messed it up? Thanks, xnappo
im85288 1493 Posted July 26, 2014 Posted July 26, 2014 It seems you missed the root folder when zipping it up. So the new one is something like skin.aeon.nox.gotham.xbmb3c-4.1.9.8c.zip - 1080i - media But it should be skin.aeon.nox.gotham.xbmb3c-4.1.9.8c.zip - skin.aeon.nox.gotham.xbmb3c - 1080i - media
xnappo 1611 Posted July 26, 2014 Posted July 26, 2014 (edited) Hi @@bigjohn - I modified the zip on the FTP server, but the HTTP server is still serving the old version. Does it take a while to transfer? Thanks, xnappo [EDIT] Nevermind Edited July 26, 2014 by xnappo
bigjohn 754 Posted July 26, 2014 Posted July 26, 2014 Yeah, sometimes it takes a little while for changes to propagate to the edges of the CDN.
Solution xnappo 1611 Posted July 26, 2014 Solution Posted July 26, 2014 @@jasonmcroy - it is fixed now. xnappo
jasonmcroy 320 Posted July 26, 2014 Author Posted July 26, 2014 Yes, I just downloaded it and it's all good now. Thanks! -Jason
monkeybounce 0 Posted September 3, 2014 Posted September 3, 2014 (edited) Disregard, working now. Edited September 3, 2014 by monkeybounce
