Leezio 0 Posted October 27, 2020 Posted October 27, 2020 (edited) Hello everyone, I have been using Emby for several months now and am having difficulty. I decided to migrate from MiniDLNA to Emby's native DLNA, and the quality is very poor. Do you have an idea of the configuration to adopt to solve this problem? I am attaching you the screenshots in comparison, between the Emby web player and Emby DLNA. Thks ^^ Bad Quality, with pixel Very qood quality Edited October 27, 2020 by Leezio Add thks ^^
Luke 42237 Posted October 28, 2020 Posted October 28, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
Leezio 0 Posted October 28, 2020 Author Posted October 28, 2020 (edited) Thank you for your return, I attach the logs and the captures which better present the problem. I have this error: Error Dlna: Error creating PlayTo device. I don't know if this is related to the problem. Thks ^^ With the Emby DLNA in VLC: With Emby Web in Firefox: embyserver.txt Edited October 28, 2020 by Leezio
Leezio 0 Posted October 29, 2020 Author Posted October 29, 2020 Hi, yes, sorry. Thks ^^. ffmpeg-remux-117c18a0-4a40-4a5d-83bd-1562ca278393_1.txt ffmpeg-transcode-012b9bd1-0a18-4841-acdd-0a77d16d1102_1.txt
Luke 42237 Posted October 30, 2020 Posted October 30, 2020 HI, these are from Firefox. I thought the issue was with Vlc?
Leezio 0 Posted October 30, 2020 Author Posted October 30, 2020 Yes, the problem is on VLC. Are these different logs ?
Luke 42237 Posted October 30, 2020 Posted October 30, 2020 How about this. Please make the problem happen again, then attach all log files that were written to during the time period of the test. Thanks.
Leezio 0 Posted October 30, 2020 Author Posted October 30, 2020 (edited) I replayed the problem but i only have the log emby updates. The transcoding logs do not return any information. As if transcoding was not called. Sorry embyserver.txt embyserver-63739526400.txt ffmpeg-remux-1f124dd3-e617-4b9b-844a-5b3c1b69e779_1.txt Edited October 30, 2020 by Leezio
Luke 42237 Posted October 30, 2020 Posted October 30, 2020 OK the log says VLC direct played the file, which means Emby served the original file as-is without any modification (transcoding). That means I'm sorry but I don't know the answer to what your issue is. Perhaps slow network performance and it's dropping frames? I really don't know but this doesn't look like an Emby-specific question.
Solution Leezio 0 Posted November 7, 2020 Author Solution Posted November 7, 2020 Hey, I found out where the problem came from. If anyone ever meets him put the solution here. In VLC, go to Tools > Preferences, then in Inputs/Codec tab. Change Hardware Accelerated decoding to something other than Automatic or VDPAU. Source: https://superuser.com/questions/1566707/ubuntu-20-04-vlc-player-not-quitting & https://bugs.launchpad.net/ubuntu/+source/vlc/+bug/1871949/comments/8 Thks ^^
