vdatanet 1619 Posted October 25, 2020 Posted October 25, 2020 (edited) Native player shows more info than MPV player: Movie playing on native player: Movie playing on MPV player: Episode playing on native player: Episode playing on MPV player: Edited October 25, 2020 by vdatanet
ebr 16334 Posted October 25, 2020 Posted October 25, 2020 Even though I disagree with the order in the native player, it looks like we need to re-order our menu items too...
vdatanet 1619 Posted October 25, 2020 Author Posted October 25, 2020 (edited) Audio and subtitle selection is also missing in native player: I have to go to the detail screen to select Audio or Subtitles and when there are more than 6 buttons, you can't reach that button, the trick is to go down and then up: https://streamable.com/c807mj Edited October 25, 2020 by vdatanet
ebr 16334 Posted October 25, 2020 Posted October 25, 2020 42 minutes ago, vdatanet said: Audio and subtitle selection is also missing in native player: I have to go to the detail screen to select Audio or Subtitles and when there are more than 6 buttons, you can't reach that button, the trick is to go down and then up: https://streamable.com/c807mj I don't believe there is any way for us to tell the native player about things that aren't in the actual stream. So, if remuxing or transcoding, this is what we're stuck with.
