Luke 42237 Posted April 15, 2023 Posted April 15, 2023 What software you using on the phone? Does it work with bubble upnp's server?
gihayes 47 Posted April 15, 2023 Author Posted April 15, 2023 I am using https://play.google.com/store/apps/details?id=com.al.dlnaserver. I will try bubble upnp's server.
gihayes 47 Posted April 15, 2023 Author Posted April 15, 2023 Wow! That's cool. Lol. Player and server. It connected immediately. When I was setting it up it appeared that I would be able to pass my Emby server to what connected to it, but when I connected with Bigscreen, I did not see Emby or any of its folders. I'll have to study it a bit to determine what is and what is not possible with it. Looks like it just grabs all media on the phone without me being able to control where it gets it from.
Luke 42237 Posted April 15, 2023 Posted April 15, 2023 OK I can compare bubble's server responses to ours. That may or may not lead to anything though because they probably vary the responses depending on what it's coming from.
Luke 42237 Posted April 15, 2023 Posted April 15, 2023 Can you download a trial of asset upnp and see if it works with that: https://www.dbpoweramp.com/asset-upnp-dlna.htm Thanks.
Luke 42237 Posted April 16, 2023 Posted April 16, 2023 OK please try this. Let's see if we get lucky. Thanks. Emby.Dlna.zip
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 Sure, I want this to work more than you do! :-). I loaded the dll's into both system and programdata's plugin folders and fired up the server with no libraries. Bigscreen connected with "No supported videos to show in this folder" message. (around 19:06). Then I added an empty movie library and tried to connect with Bigscreen (around 18:09). All I got was the spinning wheel. I added a movie to the empty Movie library, scanned it, and tried to connect to Bigscreen again. I got the spinning wheel again. embyserver (1).txt
Luke 42237 Posted April 17, 2023 Posted April 17, 2023 OK please try this with both of those tests: Emby.Dlna.zip Thanks.
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 (edited) Same procedure. Same results. The times were 20:12, 20:14, and 20:18 embyserver (1).txt Edited April 17, 2023 by gihayes
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 As long as you keep'em coming, I'll keep testing. lol. Same proceedure, same results. The times were 21:01, 21:03, and 21:07.
Luke 42237 Posted April 17, 2023 Posted April 17, 2023 11 minutes ago, gihayes said: As long as you keep'em coming, I'll keep testing. lol. Same proceedure, same results. The times were 21:01, 21:03, and 21:07. Can you please attach the server log from this last test? Thanks.
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 Sorry, I thought I had. embyserver (1).txt
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 (edited) Big Progress!!! Procedure the same. First step was the same (around 23:01). In the second step, Bigscreen was able to connect and see the empty Movies library folder !! (around 23:03). On the third step, I was able to connect and see the Movies Library, but when I clicked it, all I got was a spinning wheel (around 23:07). The movie file I am using is only 300M embyserver (1).txt Edited April 17, 2023 by gihayes
Luke 42237 Posted April 17, 2023 Posted April 17, 2023 OK hopefully this one will do the trick now: Emby.Dlna.zip
Luke 42237 Posted April 17, 2023 Posted April 17, 2023 Sorry I just realized I had accidentally removed the previous fix. Now hopefully this one will be it: Emby.Dlna.zip
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 (edited) Will re-test and repost.... Edited April 17, 2023 by gihayes
gihayes 47 Posted April 17, 2023 Author Posted April 17, 2023 (edited) It Works!!!!!!!!! Yes!!, I am soooooooo Happy Emby was one of the main reasons I got my headset! Once it connected and I started playing the video I had been using as a test, the play progress bar was counting, but I had a black picture and no sound. I added another video and that one played fine. Attached is the log. Again, thanks Luke! When will this update be available? embyserver (1).txt Edited April 17, 2023 by gihayes 2
Solution Luke 42237 Posted April 17, 2023 Solution Posted April 17, 2023 I’ll try to push it soon. Thanks for your help on this. 1
Luke 42237 Posted April 17, 2023 Posted April 17, 2023 Big Screen DLNA support with Emby Server is resolved in the Emby DLNA plugin version 1.1.4+. Thanks !
