gdeyoung 4 Posted October 24, 2020 Posted October 24, 2020 (edited) @softworkz As requested a new topic for the issue Emby Beta 4.6.0.3 Docker on Unraid 6.8.3 When playback of 4K x.265 content requires a transcode and the playback is occurring in Edge, Chrome or Firefox. The system does not spin up a HW transcode process with NV GPU. Playback in the browser of this content stops after 3-15 seconds. Watching the dashboard it does not indicate a HW transcode. Playback of the same content on the same device in Emby Theatre works fine and the server spins up HW GPU transcode of the content and can verify in the dashboard. hardware_detection-63739069906.txt ffmpeg-transcode-72449fcc-a093-4aea-8ef3-b6759a442c2e_1.txt embyserver.txt Edited October 24, 2020 by gdeyoung
softworkz 5133 Posted October 24, 2020 Posted October 24, 2020 @gdeyoung - Thanks for the logs. From the ffmpeg log it seems that the hw transcoding gets started and works just as expected. It runs for > 1 min and then it is stopped regularly by the server. Are you sure this is the right ffmpeg log? Maybe the error is rather at the client side in this case. Could you please press "F11" in Chrome, go to the 'Console' tab and see whether there are any errors logged when you try to play? Thanks.
gdeyoung 4 Posted October 24, 2020 Author Posted October 24, 2020 (edited) @softworkz Here are another set. I see the movie start in Chrome. Stops at 13 sec mark. Don't see any errors in the Chrome console they all say false, unless I'm reading it wrong. I attached it for you. I actually see the HW transcode in Chrome. I didn't in Edge. The playback stops, but the transcode continues until I close the movie. embyserver (1).txt ffmpeg-transcode-7519b16d-7ac0-4e6e-877b-496c22b6beca_1.txt Edited October 24, 2020 by gdeyoung
softworkz 5133 Posted October 24, 2020 Posted October 24, 2020 @Luke - It shows "HLS Error" entries - do you have any idea?
Luke 42241 Posted December 6, 2020 Posted December 6, 2020 Hi, are you still seeing this with the latest version?
gdeyoung 4 Posted December 6, 2020 Author Posted December 6, 2020 It is working now. Thanks for working on this and getting it fixed!
