sandro_rocha_1982 1 Posted October 21, 2020 Posted October 21, 2020 Good Morning. My Emby is not saving the video's progress. This way I cannot resume. I don't know what happened or when it happened. I am using the beta version 4.6.0.2. ps: in addition to the problem mentioned, I'm having playback problems in the Android application. The video does not start or hangs too much. embyserver.txt embyserver-63738828984.txt embyserver-63738835200.txt
Luke 42237 Posted October 21, 2020 Posted October 21, 2020 Hi there, please go over an example. Thanks.
sandro_rocha_1982 1 Posted October 23, 2020 Author Posted October 23, 2020 On 10/21/2020 at 1:02 PM, Luke said: Hi there, please go over an example. Thanks. An example? I don't know if I understood ... I started watching the series Raised By Wolves and Star Trek: Lower Decks. No episode that I stopped in the middle appeared on the home screen to continue and when starting, Emby didn't ask if I wanted to continue where I left off. I had to start from the beginning and move on to the last point I saw.
Luke 42237 Posted October 24, 2020 Posted October 24, 2020 In other words, please provide discussion of what you watched, when you did that, what device/app, along with what position you stopped and how you stopped playback, and then also what you observed after stopping. Thanks.
sandro_rocha_1982 1 Posted November 3, 2020 Author Posted November 3, 2020 On 10/24/2020 at 2:39 PM, Luke said: In other words, please provide discussion of what you watched, when you did that, what device/app, along with what position you stopped and how you stopped playback, and then also what you observed after stopping. Thanks. Okay. Yesterday, November 1st, I started watching "Lovecraft Country - S01E07" on the WebOS 3.5 application. I stopped playback at 24 minutes, using the stop button on the controller. I went back to the home screen and there was the episode among the videos to continue. This morning, November 2nd, I opened the Android app on the phone and the episode was still on the home screen, ready to continue. On the same day, at night, the episode had disappeared from the home screen. ps: I'm using the latest beta version of the server. ps2: apparently, and i'm not sure or how to test, the position of the films are being saved. As soon as I installed the latest beta, I started playing "Back to the Future" and it is still on the home screen. It's been a few days.
Luke 42237 Posted November 3, 2020 Posted November 3, 2020 Great, thanks. Which log file was the one modified during the time period of that activity?
sandro_rocha_1982 1 Posted November 4, 2020 Author Posted November 4, 2020 On 11/3/2020 at 4:27 AM, Luke said: Great, thanks. Which log file was the one modified during the time period of that activity? I watched another episode halfway through, waited to appear on the home screen and picked up the log. After the episode disappeared from the home screen, the next day, I got the new log. Both are attached. embyserver.txt embyserver-63740044810.txt embyserver0.txt
vdatanet 1619 Posted November 4, 2020 Posted November 4, 2020 I see you are using Trakt, maybe Trakt is reseting the progress position.
sandro_rocha_1982 1 Posted November 4, 2020 Author Posted November 4, 2020 4 minutes ago, vdatanet said: I see you are using Trakt, maybe Trakt is reseting the progress position. I will uninstall Trakt and test it. Thanks! I just don't understand why movies stay on the home screen indefinitely. ps: just being able to disable plugins would be a good thing.
vdatanet 1619 Posted November 4, 2020 Posted November 4, 2020 (edited) 2 minutes ago, sandro_rocha_1982 said: I will uninstall Trakt and test it. Thanks! I just don't understand why movies stay on the home screen indefinitely. ps: just being able to disable plugins would be a good thing. Check your progress on Trakt at: https://sharkykh.github.io/tppm/ There you can manually clear progress for items you don't want, after that do a Trakt import. Edited November 4, 2020 by vdatanet
vdatanet 1619 Posted November 4, 2020 Posted November 4, 2020 You also have this plugin: Simkl TV Tracker 1.0.0.0
Luke 42237 Posted November 4, 2020 Posted November 4, 2020 Yea i would try removing those plugins, then restart the server and see if the issue persists. Thanks.
sandro_rocha_1982 1 Posted November 4, 2020 Author Posted November 4, 2020 22 minutes ago, vdatanet said: Check your progress on Trakt at: https://sharkykh.github.io/tppm/ There you can manually clear progress for items you don't want, after that do a Trakt import. At Trakt, progress is normal. 1
sandro_rocha_1982 1 Posted November 4, 2020 Author Posted November 4, 2020 28 minutes ago, vdatanet said: You also have this plugin: Simkl TV Tracker 1.0.0.0 I got to try Simkl but I didn't really understand how it works, I couldn't import my Emby library. I uninstalled it with Trakt.
sandro_rocha_1982 1 Posted November 6, 2020 Author Posted November 6, 2020 On 11/4/2020 at 1:58 PM, vdatanet said: You also have this plugin: Simkl TV Tracker 1.0.0.0 Good Morning. I tested the server without the Simkl plugin (I kept Trakt) and, apparently, the progress of the episodes is being saved as shown in the screenshots. It's been over 24 hours since the episode I started continues on the home screen. The problem appears to be in the Simkl plugin.
