josejosito 0 Posted October 21, 2020 Posted October 21, 2020 Hola sale este error en todos los disp de un amigo en su casa me asegure que puso la ip bien y el usuario sólo le pasa a el sabéis porque?
ebr 16334 Posted October 21, 2020 Posted October 21, 2020 Hi. Can other devices on other networks access your server remotely? Are you sure you gave him the WAN address and proper port as setup in your router port forwarding?
josejosito 0 Posted October 21, 2020 Author Posted October 21, 2020 Si se puede tengo varios disp de otras redes se conectan sin problema y si le di todo bien lo revise yo todo es el sólo que no puede entrar le sale ese error
ebr 16334 Posted October 21, 2020 Posted October 21, 2020 Assuming he is actually typing exactly what you tell him, it could be something on his network blocking access. Can you try using Connect? Emby Connect
josejosito 0 Posted October 21, 2020 Author Posted October 21, 2020 Quizás tenga algún problema de bloqueo por la compañía o algo le diré abra el puerto 8096 a ver si así entra
Banquero 38 Posted October 21, 2020 Posted October 21, 2020 Hola, lo está viendo en una TV con Android TV, verdad? Dile a tu amigo que cambie el nombre del dispositivo y ponga un nombre en minúscula sin espacios. Por ejemplo tvsalon. Saludos...
ebr 16334 Posted October 22, 2020 Posted October 22, 2020 22 hours ago, Banquero said: Hello, you are watching it on a TV with Android TV, right? Tell your friend to rename the device and put a lowercase name with no spaces. For example tvsalon. Greetings... This is also a good thing to try although spaces aren't a problem, some accented characters may be. This will be remedied in the next release of the app.
