Bambu Utila 9 Posted October 21, 2020 Posted October 21, 2020 Hi, I recently moved my Emby server from Windows 10 to OpenMediaVault in Docker. When a movie was added to Emby when it was running on Windows 10, 2 folders would be created: extrafanart and extrathumbs Now on OMV in Docker when a movie is added those folders are no longer created. the extrafanart is still there in the main folder of the movie, but it doesn't seem like Kodi is picking the extrafanart up when not in those folders. Am i just missing a setting? I've looked everywhere, but can't seem to find the option to create those folders
PenkethBoy 2068 Posted October 21, 2020 Posted October 21, 2020 Nope they were removed from emby as kodi does not support them anymore Dumb idea as was a good way to keep fanart in one place Emby still reads the files if they are in the extrafanart directory so no need to remove them just wont get any going forward
Bambu Utila 9 Posted October 21, 2020 Author Posted October 21, 2020 47 minutes ago, PenkethBoy said: Nope they were removed from emby as kodi does not support them anymore Dumb idea as was a good way to keep fanart in one place Emby still reads the files if they are in the extrafanart directory so no need to remove them just wont get any going forward What do you mean by Kodi doesn't support then anymore? For me the movies that don't contain the extrafanart folder don't rotate their backgrounds
PenkethBoy 2068 Posted October 21, 2020 Posted October 21, 2020 newest version of kodi does not - go check on kodi forum
Bambu Utila 9 Posted October 21, 2020 Author Posted October 21, 2020 7 hours ago, PenkethBoy said: newest version of kodi does not - go check on kodi forum I'm running Kodi 18.8 and it still works there. Can you give me a ling that covers this? I looked on the Kodi forum but didn't see anything about this.
Bambu Utila 9 Posted October 21, 2020 Author Posted October 21, 2020 This is very strange. For me it has the opposite behavior. All movies added with no extrafanart folder do not show the extra back grounds. All my old movies with the folder do. I'm running Emby Server 4.5.2 on docker and Kodi 18.8 on Windows 10
pünktchen 1411 Posted October 21, 2020 Posted October 21, 2020 The skin you're using in Kodi is probably looking for the "extra" folders. Kodi itself, i mean the database, never had used those extrafanart. It was always done either directly by a Kodi skin or an addon like ArtworkHelper, ArtworkBeef or SkinHelperService. The new way of storing extra art alongside the media is the way to go for Kodi: https://kodi.wiki/view/Movie_artwork With Kodi 19 you don't even have to edit the advancedsettings.xml, it's all in the GUI.
Bambu Utila 9 Posted October 21, 2020 Author Posted October 21, 2020 1 hour ago, pünktchen said: The skin you're using in Kodi is probably looking for the "extra" folders. Kodi itself, i mean the database, never had used those extrafanart. It was always done either directly by a Kodi skin or an addon like ArtworkHelper, ArtworkBeef or SkinHelperService. The new way of storing extra art alongside the media is the way to go for Kodi: https://kodi.wiki/view/Movie_artwork With Kodi 19 you don't even have to edit the advancedsettings.xml, it's all in the GUI. Yes, I'm using Titan Bingie and that skin heavily uses SkinHelper Service. Is there a way to solve this problem?
Bambu Utila 9 Posted October 23, 2020 Author Posted October 23, 2020 It seems this change has not just affected Kodi, but also Emby. I can only change the order of the background images in Emby for newly added movies that follow the new folder structure (no extrafanart). For all my movies that still follow the old style i get an error message when i want to change the background image order Is there a solution for this? I don't rteally feel like changing the folder structure for 1000+ movies
Luke 42246 Posted October 24, 2020 Posted October 24, 2020 4 hours ago, Bambu Utila said: It seems this change has not just affected Kodi, but also Emby. I can only change the order of the background images in Emby for newly added movies that follow the new folder structure (no extrafanart). For all my movies that still follow the old style i get an error message when i want to change the background image order Is there a solution for this? I don't rteally feel like changing the folder structure for 1000+ movies Hi, server log?
Bambu Utila 9 Posted October 24, 2020 Author Posted October 24, 2020 5 hours ago, Luke said: Hi, server log? Hi Luke, here's the log. I restarted Emby, then first i went to a movie where it's no issue to change the order of the background images, then i went to a movie where it's not possible anymore and tried to change the order a few times there. This happens for every movie i tried so far that still has fanart in the extrafanart folder. That first movie i tried has been added after an update to Emby where it no longer creates the extra folders. embyserver.txt
Luke 42246 Posted October 24, 2020 Posted October 24, 2020 10 hours ago, Bambu Utila said: Hi Luke, here's the log. I restarted Emby, then first i went to a movie where it's no issue to change the order of the background images, then i went to a movie where it's not possible anymore and tried to change the order a few times there. This happens for every movie i tried so far that still has fanart in the extrafanart folder. That first movie i tried has been added after an update to Emby where it no longer creates the extra folders. embyserver.txt 117.97 kB · 0 downloads It looks like the server is being denied write access to the folder in order to be able to swap the images around: System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied.
Bambu Utila 9 Posted October 24, 2020 Author Posted October 24, 2020 2 hours ago, Luke said: It looks like the server is being denied write access to the folder in order to be able to swap the images around: System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. That's strange, because i've already reset the permissions to everybody read/write and i made sure to check folder inheritance for the permissions. If i go to the shared drives with movies i can move things around without any problem. Is there anything else i can check? I can't understand why it can go so far into the folder structure, but not that last folder?
Luke 42246 Posted October 26, 2020 Posted October 26, 2020 Is it possible the subfolders have their own permissions set on them?
Bambu Utila 9 Posted October 27, 2020 Author Posted October 27, 2020 On 10/25/2020 at 8:24 PM, Luke said: Is it possible the subfolders have their own permissions set on them? I found the issue! For some reason my moves folder was owned by root while the tv folder was owned by my user. Once i changed the owner of the movies folder it is working again. Now i just need to figure out how my skin can work with this new way Since there is no more extrafanart folder my skin doesn't pick up the extra fanart anymore
FrostByte 5454 Posted October 27, 2020 Posted October 27, 2020 Someone wrote a PS script to create extrafanart and move the appropriate jpg files. You could use that in the meanwhile. Emby still supports the folder, it just doesn't create them anymore. I run it from Win10 to my server on Synology. 1
PenkethBoy 2068 Posted October 27, 2020 Posted October 27, 2020 lol - Someone - wonder who that could possibly be?
FrostByte 5454 Posted October 28, 2020 Posted October 28, 2020 18 hours ago, PenkethBoy said: lol - Someone - wonder who that could possibly be? Some dude in Warrington 1
PenkethBoy 2068 Posted October 28, 2020 Posted October 28, 2020 oh him - dont believe anything he says 1
