sleepy 10 Posted October 20, 2020 Posted October 20, 2020 Well, quite suddenly Emby will not load. I just get a black screen for a few minutes and then I get a WMC error "Can't load Emby" or similar? I don't know what has changed from yesterday but I tried reinstalling both the Emby Server and WMC Clients and both stable and beta versions to no avail. Log attached. MBClassic-20102020a54bcc9c70c04e8e893fa238a7893435.log
Luke 42237 Posted October 20, 2020 Posted October 20, 2020 Hi, what version of Emby for WMC and what version of Emby Server are you running? What version of Windows is this on?
ebr 16331 Posted October 21, 2020 Posted October 21, 2020 Looks like 317 and 4.5.2. Your server IP address changed which is why it takes a long time to start up. If you are getting an "Invalid Application" error, please find the error or message in the Windows Event Log. Thanks.
sleepy 10 Posted October 21, 2020 Author Posted October 21, 2020 (edited) Evening, apologies for the delay but I was working late. Logs attached thanks. Media Center Log.evtx Edited October 21, 2020 by sleepy
ebr 16331 Posted October 21, 2020 Posted October 21, 2020 Hi. Can you just tell or show us what errors are there at the time you try to start the application? Also, what version of Windows?
sleepy 10 Posted October 21, 2020 Author Posted October 21, 2020 7 minutes ago, ebr said: Hi. Can you just tell or show us what errors are there at the time you try to start the application? Also, what version of Windows? Hi, I get the "Invalid Application" "Unable to launch emby" error. It's been running absolutely fine until now. I suspect a config file has corrupted somehow? I'm running Windows 10 btw.
ebr 16331 Posted October 21, 2020 Posted October 21, 2020 2 hours ago, sleepy said: I'm running Windows 10 btw. Did Windows update? That is a common source of problems with WMC on Win 10 since it isn't really supported. Can you look in your event viewer for an event that happens right at the same time as the Invalid Application? What does it say? Do other portions of WMC work?
dansblackcat 37 Posted October 22, 2020 Posted October 22, 2020 As referenced by ebr, Windows 10 updates cause dramas with WMC. It's pretty much the main reason I rolled back to W7. Updates constantly broke media centre for me and I spent more time trying to get/keep it running than I did enjoying it. Only option was to turn updates off. But then I had an out of date operating system, which I wasn't a fan of. However many people get it working with little to no issues. Hopefully you can be one.
Solution sleepy 10 Posted October 22, 2020 Author Solution Posted October 22, 2020 I can confirm that it was a Windows update that caused the issues. I reinstalled the WMC installation files and it's all back up and running again. Cheers all.
