SteveFintel 30 Posted March 29, 2023 Posted March 29, 2023 Since this behavior is observable on multiple PCs under Windows 10 and 11, and multiple versions of Emby server is it really necessary to submit logs? I think if the devs just try it, they'll be able to replicate this behavior immediately.
ebr 16335 Posted March 29, 2023 Posted March 29, 2023 22 hours ago, Sammy said: Oh sorry.. I started a recording then exited to the main screen, waited a minute or so and then went to the guide to tune to the channel but when I selected the channel I was not greeted with the choice to Play from Beginning or Play Live, selections I know were there before. Additionally, the active recording does not show up on the main screen or in the Recordings section under LiveTV even though I selected to show Active Recordings on the Main Screen. Okay, that feature only exists in the Android TV app at this time but it relies on the recording existing in the server and it appears it doesn't yet for you: 22 hours ago, Sammy said: Additionally, the active recording does not show up on the main screen Once that shows up, the feature would be available to the app.
Sammy 791 Posted March 29, 2023 Posted March 29, 2023 Thanks, @ebr! Typically how long must one wait for it to show up? I am probably wrong but it seemed almost instantaneous before.
Sammy 791 Posted March 29, 2023 Posted March 29, 2023 @ebr Just tried again to no avail. I waited about 10 minutes. New AndroidTV Log sent just now. User TVTime Attached Server and hardware detection logs but there was no transcode log to attach this time. Something's BROKEN! hardware_detection-63815674264.txtembyserver (63).txt It shows recording in the Channels Page but not as an Active Recording on the Home Page or Recordings Page in the server. It doesn't show on the Server Dashboard either.
Sammy 791 Posted March 29, 2023 Posted March 29, 2023 (edited) Progress in .27! The Recording in Progress shows up on the Home Screen in the Chrome Browser (Haven't checked other apps yet). The Recording in Progress is "Seekable and Pausable". Playing from the On Now Strip or Guide starts from the live position with no option to start from the beginning of the recording. Playback here is forward seekable but not backward seekable beyond where the Live Playback started regardless if the recording started earlier. The Time Bar in the active recording starts from 0:00 rather than the system clock time of the Server (EDIT) [I]when the recording started.[/i] Edited March 30, 2023 by Sammy 1
ebr 16335 Posted March 30, 2023 Posted March 30, 2023 Right - as far as playing from the beginning, this is all about the recording showing up in the server. Until that happens, the app will have no knowledge of it. In any app other than Android TV, if you want to play from the beginning, play the recording, not the channel.
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 12 minutes ago, ebr said: Right - as far as playing from the beginning, this is all about the recording showing up in the server. Until that happens, the app will have no knowledge of it. In any app other than Android TV, if you want to play from the beginning, play the recording, not the channel. I'll check out the server to make sure it shows there then check from the Guide in the AndroidTV app. Also note my edit above Re: Time Bar in the active recording.
SteveFintel 30 Posted March 30, 2023 Posted March 30, 2023 13 minutes ago, ebr said: Right - as far as playing from the beginning, this is all about the recording showing up in the server. Until that happens, the app will have no knowledge of it. In any app other than Android TV, if you want to play from the beginning, play the recording, not the channel. Is there any reason that behavior is limited to Android TV? If I launch a recording in process from Android TV from either On Now or Recordings, I see a Play from beginning button. On Emby for Web or Emby for Windows Desktop, I don't.
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 1 hour ago, ebr said: Right - as far as playing from the beginning, this is all about the recording showing up in the server. Until that happens, the app will have no knowledge of it. In any app other than Android TV, if you want to play from the beginning, play the recording, not the channel. That worked but I got an Unable to Load Subtitle error. I tried turning CC's off and on again to no avail. AndroidTV Log Sent just now. User Name is TVTime. Attached are server log, transcode logs and hardware detection log. hardware_detection-63815758200.txtffmpeg-transcode-315c0ec1-40dd-4eb7-bac3-ff7e003729c9_1.txtffmpeg-remux-32367408-524b-4473-8ea6-b14b79854666_1.txtffmpeg-transcode-8aacf188-35dd-49b9-91a3-132c3167712b_1.txtembyserver (64).txt
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 51 minutes ago, SteveFintel said: Is there any reason that behavior is limited to Android TV? If I launch a recording in process from Android TV from either On Now or Recordings, I see a Play from beginning button. On Emby for Web or Emby for Windows Desktop, I don't. Because the coding isn't done yet.
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 Keep in mind that Emby has two full time developers and one ad hoc developer, AFAIK. It takes time for things to get done sometimes but they're always working on it and responsive in the forums to issues too. IDK how they do it actually.
SteveFintel 30 Posted March 30, 2023 Posted March 30, 2023 I wasn't trying to be sarcastic. The team has taken on a project of tremendous scope. There are multiple ports of emby-server (on vastly different OS bases) and I have yet to find a device that doesn't have some version of Emby client software available. I've found workarounds for most of the issues I've encountered. It would help (me at least) to see a roadmap for where the team is headed.
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 I know you weren't being sarcastic. Sorry if it came off that way.
Carlo 4561 Posted March 30, 2023 Posted March 30, 2023 1 hour ago, Sammy said: Keep in mind that Emby has two full time developers and one ad hoc developer, AFAIK. It takes time for things to get done sometimes but they're always working on it and responsive in the forums to issues too. IDK how they do it actually. Hasn't been two developers in a long time!
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 1 minute ago, cayars said: Hasn't been two developers in a long time! Tells you what I know! Care to share? A range even?
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 Are you counting the third party developers too? I figured most of them worked on plugins mainly but there's only a few working on the core.
Luke 42242 Posted March 30, 2023 Posted March 30, 2023 We have developers that we keep out of the forum just so that they can focus on getting things done. 1 1
Sammy 791 Posted March 30, 2023 Posted March 30, 2023 Guess it ain't MediaBrowser 3.x any longer! Good to hear, @Luke! 2
Sammy 791 Posted April 6, 2023 Posted April 6, 2023 (edited) Seems .29 has broken this again. Probably not. I think it was a network error where my shield wasn't talking to my server to know the recording was occurring. Edited April 6, 2023 by Sammy
SteveFintel 30 Posted April 12, 2023 Posted April 12, 2023 .29 has definitely regressed for me. On web and Emby Theater for Windows, I can skip the first 30 seconds, but if I watch the program for a few minutes and then try to skip, the picture just freezes - even after waiting 20-30 seconds.
Sammy 791 Posted April 12, 2023 Posted April 12, 2023 33 minutes ago, SteveFintel said: .29 has definitely regressed for me. On web and Emby Theater for Windows, I can skip the first 30 seconds, but if I watch the program for a few minutes and then try to skip, the picture just freezes - even after waiting 20-30 seconds. Logs? 1
