EODCrafter 181 Posted October 20, 2020 Posted October 20, 2020 We are gonna need ability to use M3U Provider Login to use our TV in Emby.... Any word on when you could add that? @Luke
Luke 42275 Posted October 20, 2020 Posted October 20, 2020 This is just a regular m3u tuner host, right? Normally you can put your username and password in the url.
Carlo 4561 Posted October 22, 2020 Posted October 22, 2020 m3u is just a file or URL to the system. There is no "login" used for this. If you have to login to download a m3u file that's far outside the norm and will break most apps since this is very uncommon. In this case the proper thing to do is manually download the file and then point your apps including Emby to the local m3u file you've downloaded.
Carlo 4561 Posted October 22, 2020 Posted October 22, 2020 If the login is only needed when retrieving the m3u file you could try the standard login for URLs similar to: http://username:password@www.somedomain.com/some_thing
jad3675 26 Posted October 22, 2020 Posted October 22, 2020 I think he's talking about a lot of providers moving away from m3u streams and instead forcing XC/API integration. FWIW, m3u4u.com can take an CX login and make a m3u url out of it. John 1
Carlo 4561 Posted October 22, 2020 Posted October 22, 2020 14 minutes ago, jad3675 said: I think he's talking about a lot of providers moving away from m3u streams and instead forcing XC/API integration. Thanks John, Yea, that a completely different animal.
fuzzynet 1 Posted October 25, 2020 Posted October 25, 2020 along with ability to filter groups/channels by user please.
ebr 16351 Posted October 25, 2020 Posted October 25, 2020 52 minutes ago, fuzzynet said: yes we need this asap. Hi. Need exactly what asap? m3u urls already support login information.
fuzzynet 1 Posted October 25, 2020 Posted October 25, 2020 5 minutes ago, ebr said: Hi. Need exactly what asap? m3u urls already support login information. As @jad3675 stated above many providers are blocking m3u downloads and instead forcing XC/API integration. One of my providers has done this and I can no longer use it in Emby.
ebr 16351 Posted October 25, 2020 Posted October 25, 2020 Just now, fuzzynet said: As @jad3675 stated above many providers are blocking m3u downloads and instead forcing XC/API integration. One of my providers has done this and I can no longer use it in Emby. I apologize but we will not be building direct integration to XC into Emby.
fuzzynet 1 Posted October 25, 2020 Posted October 25, 2020 On 10/22/2020 at 6:49 AM, jad3675 said: I think he's talking about a lot of providers moving away from m3u streams and instead forcing XC/API integration. FWIW, m3u4u.com can take an CX login and make a m3u url out of it. John That site will be blocked my most providers soon.
