sward 28 Posted October 19, 2020 Posted October 19, 2020 Hello - any plans to support this new Hauppauge capture device? This would solve a lot of problems for me as most of my sources today are 4k: https://hauppauge.com/pages/products/data_hdpvrpro60.html
Luke 42238 Posted October 19, 2020 Posted October 19, 2020 Hi there, yes expanded Hauppauge tuner support is planned for the future. Thanks.
sward 28 Posted October 19, 2020 Author Posted October 19, 2020 Please note this is a Hauppauge capture card, not a tuner. It is similar to the Colossus 2, except that this can take in a 4k source.
Luke 42238 Posted October 20, 2020 Posted October 20, 2020 Ok yes I believe the lower level support we're working on will cover both capture cards and tuner cards.
sward 28 Posted October 20, 2020 Author Posted October 20, 2020 Do we have an ETA on when this expanded support for Hauppauge devices will become available? I've been using Emby for 4 months now, and every time I ask about something I'm being told that it's being worked on, and yet the months go by and nothing seems to change. Should be possible to do incremental improvements & updates to existing codebase without having to wait for some monolithic release that will address all concerns, and which may be years in the making.
Luke 42238 Posted October 20, 2020 Posted October 20, 2020 Hi, no ETA but we're working hard on it. Thanks.
SHSPVR 125 Posted October 26, 2020 Posted October 26, 2020 On 10/19/2020 at 2:06 PM, sward said: Hello - any plans to support this new Hauppauge capture device? This would solve a lot of problems for me as most of my sources today are 4k: https://hauppauge.com/pages/products/data_hdpvrpro60.html It is petty much point less to get as it can only record in down convert 1080p not 4k and it is just for 4k pass thru as 30fps and I doubt you be able get around HDCP but I haven't test it and 4k is still not main steam it a long way off for many folk unless it OTA
sward 28 Posted October 26, 2020 Author Posted October 26, 2020 I don't want or need to record in 4K but most of my sources are 4k, that's why this device would help me a lot. Currently I have to reduce my Verizon FiOS One STB's output resolution to 1080p since that's the max that the Hauppauge Colossus 2 capture card supports, but unfortunately my STB seems to reset itself to its 4k factory default quite frequently, and then I cannot record anything.
sward 28 Posted October 26, 2020 Author Posted October 26, 2020 Forgot to ask - if they add WinTV support for the Hauppauge HD PVR Pro 60, then I believe Emby can control this capture card, correct? I'm assuming here that Emby can control any Hauppauge device that's compatible with WinTV.
SHSPVR 125 Posted October 26, 2020 Posted October 26, 2020 14 minutes ago, sward said: Forgot to ask - if they add WinTV support for the Hauppauge HD PVR Pro 60, then I believe Emby can control this capture card, correct? I'm assuming here that Emby can control any Hauppauge device that's compatible with WinTV. It not support under WinTV not even under NextPVR nor any other app and as far I know of it only support under Hauppauge Capture and OBS sorry.
