OnyxUK 84 Posted October 19, 2020 Posted October 19, 2020 hey guys, i have been getting together a horror section for my server to show at halloween, and had a look in the parental controls and would like to ask if it would be possible to instead hiding the film (s) to maybe have something like sky does where you can see the film displayed with all artwork but to watch the film or trailer you would have to put in a pin code to allow the playback. the code could be the same as the local pin code for (your) local network so once you have chosen your code it will work for both parental controls and local network. this could be a great idea to also mention that in the [metadata manager] you could also have an option to have a tick box to set up for parental control pin code required if you would like to select certain films / tv shows. or for batches you can then go to parental control main settings as they are now. hope this makes some sense as im fairly tired haha
