Guest Posted August 23, 2021 Posted August 23, 2021 Is the new android TV build available for testing now?
clarkss12 304 Posted August 23, 2021 Posted August 23, 2021 (edited) Was trying to test the new version, "39", but now my HEVC channels will NOT even play, only a circle going round and round. At first, I updated to the "39" version on one of my boxes that shows the AC-4 codec as a supported codec, got the circle going round and round. I tried setting it to "direct play Live TV", but that did not matter. Next, I tested two more boxes, including the Nvidia Shield, but did NOT update to the ".39" version, the HEVC channels with AC-4 audio still would not play, just the circle going round and round. Emby DOES grab the tuner, but will not play it............. Strange, was working a couple days ago, has to be something on my end. Edit: The HEVC channels will play under Windows, but obviously no audio......... Still plays on my Galaxy S20 with audio. Edited August 23, 2021 by clarkss12
MBSki 1115 Posted August 23, 2021 Posted August 23, 2021 1 hour ago, clarkss12 said: Was trying to test the new version, "39", but now my HEVC channels will NOT even play, only a circle going round and round. Still plays on my Galaxy S20 with audio. Yep, EXACTLY the same experience here. I changed the settings, but nothing plays on my Shield TV Pro.
ebr 16334 Posted August 23, 2021 Posted August 23, 2021 4 hours ago, mbarylski said: Yep, EXACTLY the same experience here. I changed the settings, but nothing plays on my Shield TV Pro. If the server and ffmpeg is involved, then they won't play due to the unrecognized audio codec. So you have to be sure that it is truly direct playing. IOW - you probably are going to need to test on a recording.
MBSki 1115 Posted August 23, 2021 Posted August 23, 2021 26 minutes ago, ebr said: If the server and ffmpeg is involved, then they won't play due to the unrecognized audio codec. So you have to be sure that it is truly direct playing. IOW - you probably are going to need to test on a recording. I am using a recording and the stats for nerds says direct play, but it spins anyway. Should I send logs from the app?
ebr 16334 Posted August 23, 2021 Posted August 23, 2021 Just now, mbarylski said: I am using a recording and the stats for nerds says direct play, but it spins anyway. Should I send logs from the app? Are any ffmpeg logs generated on the server? Yes, send a log.
MBSki 1115 Posted August 23, 2021 Posted August 23, 2021 39 minutes ago, ebr said: Are any ffmpeg logs generated on the server? Yes, send a log. Yep, I'll send you a PM with logs. I sent the logs from the app
ebr 16334 Posted August 24, 2021 Posted August 24, 2021 14 hours ago, mbarylski said: Yep, I'll send you a PM with logs. I sent the logs from the app Okay, this is expected because your device is not reporting support for AC4 08-23 18:19:21.037 14299 14299 I System.out: Reported device audio support is: ,ac3,eac3,dts,dtshd,trueHD
MBSki 1115 Posted August 24, 2021 Posted August 24, 2021 8 minutes ago, ebr said: Okay, this is expected because your device is not reporting support for AC4 08-23 18:19:21.037 14299 14299 I System.out: Reported device audio support is: ,ac3,eac3,dts,dtshd,trueHD Interesting. So, the Shield TV Pro doesn't support AC-4 or it just isn't reporting it? Seems like of all the available devices, the Shield would be the one to support it. Odd if it doesn't.
clarkss12 304 Posted August 24, 2021 Posted August 24, 2021 I tested on a device that specifically says it supports the DD AC-4 audio codec, but the video will not play, just a circle going round and round. Here is the ffmpeg log. ffmpeg-remux-bef10ed4-f17a-45e2-bc1b-691abfab4235_1.txt 1
Carlo 4561 Posted August 24, 2021 Posted August 24, 2021 You likely need to wait for the next Server beta and then try again. 1
clarkss12 304 Posted August 24, 2021 Posted August 24, 2021 2 minutes ago, cayars said: You likely need to wait for the next Server beta and then try again. No, rush. Thanks
ebr 16334 Posted August 24, 2021 Posted August 24, 2021 I can see from that log that the app did recognize that the device supports AC4 but the server still caused a remux due to "audio codec not supported". Perhaps the next beta will recognize it properly.
MBSki 1115 Posted August 24, 2021 Posted August 24, 2021 1 hour ago, clarkss12 said: I tested on a device that specifically says it supports the DD AC-4 audio codec. What device did you use?
clarkss12 304 Posted August 24, 2021 Posted August 24, 2021 26 minutes ago, mbarylski said: What device did you use? I used a Mecool KM1. I have a lot of different Android boxes, but that is the only one that specifically states that it supports the DD AC-4 audio codec.
MBSki 1115 Posted August 24, 2021 Posted August 24, 2021 28 minutes ago, clarkss12 said: I used a Mecool KM1. I have a lot of different Android boxes, but that is the only one that specifically states that it supports the DD AC-4 audio codec. Interesting, thanks. It seems the Shield TV Pro should as well. Not sure why it isn't reporting that it does.
jrwalte 17 Posted August 24, 2021 Posted August 24, 2021 4 minutes ago, mbarylski said: Interesting, thanks. It seems the Shield TV Pro should as well. Not sure why it isn't reporting that it does. The Shield is using hardware that officially supports AC4, but maybe because the codec was still being finalized when 2019 Shield released, Nvidia needs to release an update? 1
MBSki 1115 Posted August 24, 2021 Posted August 24, 2021 28 minutes ago, jrwalte said: The Shield is using hardware that officially supports AC4, but maybe because the codec was still being finalized when 2019 Shield released, Nvidia needs to release an update? Yea, possibly, except this forum thread seems to indicate that it's already supported. https://www.nvidia.com/en-us/geforce/forums/shield-tv/9/463925/does-the-2019-shield-tv-pro-support-dolby-ac-4-dec/
jrwalte 17 Posted August 24, 2021 Posted August 24, 2021 yes the hardware supports it but that doesn't mean all the software has been told so. For instance, the exoplayer may need an update to say AC4 is supported and that it can either decode or pass it on if connected device shows support. Heck, the listed supported formats in the Shield doesn't even show AC4 for you to select to pass on or not.
ebr 16334 Posted August 24, 2021 Posted August 24, 2021 17 minutes ago, jrwalte said: For instance, the exoplayer may need an update to say AC4 is supported Exo already recognizes AC4 so that is not where it is. I can see it Clarkss' log that his device is reporting support for AC4. 18 minutes ago, jrwalte said: Heck, the listed supported formats in the Shield doesn't even show AC4 for you to select to pass on or not Right - which means either it isn't really supported or the software at a lower level (Shield firmware) doesn't recognize it. You can see the AC-4 option in the image posted above. This is from the device Clarkss was using.
clarkss12 304 Posted August 24, 2021 Posted August 24, 2021 New developments ....... Now, I can't get Emby to play the HEVC streams from my Windows PC nor my Galaxy S20. Yesterday, they played fine. Yesterday I reset my Asus router......... ffmpeg-remux-dd9fc0c2-8f01-4613-9e74-359368f0f112_1.txt
MBSki 1115 Posted August 24, 2021 Posted August 24, 2021 45 minutes ago, ebr said: Right - which means either it isn't really supported or the software at a lower level (Shield firmware) doesn't recognize it. That stinks. Hopefully it's just that the Shield needs a firmware upgrade. If hardware doesn't support AC-4 though, will Emby be able to transcode it?
ebr 16334 Posted August 24, 2021 Posted August 24, 2021 54 minutes ago, mbarylski said: will Emby be able to transcode it? We hope so but we don't know yet. This is a new proprietary format from Dolby. 1
emveepee 133 Posted August 24, 2021 Posted August 24, 2021 (edited) If you guys are interested I attached the latest ExoPlayer demo apk I included the reference AC-4 sample https://testassets.dashif.org/#feature/details/586fb3879ae9045678eab593 links in the build. I don't have any AC-4 devices other than the Roku Ultra and I didn't tweak the demo but it might show what your device can do. Logcat is showing me that these are ac4 so ExoPlayer is getting that far. Edit: I updated the attachment to a release build and was able to confirm that it plays ac4 on my wife's Huawei phone. Martin release.zip Edited August 25, 2021 by emveepee
