ebr 16334 Posted August 22, 2021 Posted August 22, 2021 16 hours ago, emveepee said: @clarkss12 does that v107.mpeg file have 5:1 playable? @ebr here is an mp4 of that file. Tools used eac3to to extract hevc and the second audio track and then muxed with reference ac4 mp4 muxer from github. These files should play on Roku Ultra directly. Martin v107.mp4 9.32 MB · 0 downloads I cannot access that video.
emveepee 133 Posted August 22, 2021 Posted August 22, 2021 It was a simple forum upload but just tried in FF and right clicked and there was an option to "Save video as". Maybe try with curl https://emby.media/community/uploads/monthly_2021_08/v107.mp4.3ffe6ab48fea728c739401db0bc74fe2.mp4 Martin
ebr 16334 Posted August 22, 2021 Posted August 22, 2021 I was finally able to get that video. Even forcing it to direct play on my Shield connected to an Atmos receiver, it will not play the audio. 2021-08-22 10:50:01.729 645-645/tv.emby.embyatv D/EventLogger: [ ] Track:0, id=1, mimeType=audio/ac4, channels=2, sample_rate=48000, language=und, supported=NO_UNSUPPORTED_TYPE I'm pretty sure Exo is looking at the same API we are for support so it isn't allowing the track to play because the system does not report support for it.
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 @ebr have you checked to make sure your receiver specifically supports AC-4? Just because it can handle Atmos doesn't mean it can do AC-4.
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 I don't have ATSC 3 in my area yet so I can't personally test. Am I correct you guys can record ATSC 3 correctly but can't play it back on most devices right now because of the AC-4 audio? I ask because I've got a build of ffmpeg for windows that can transcode the audio to AAC or AC3. This seems to work for the few AC-4 sample files I have. This would not help with real time Live TV but could be used on recordings to allow proper playback. Would something like this be of use to any of you short term? 1
Guest Posted August 22, 2021 Posted August 22, 2021 (edited) @cayars Yes, we can record it just fine through emby. It saves the video in HEVC and the AC4 audio tracks, however emby doesn't seem to realize they exist in stable and in the beta it sees the tracks but cant deal with them yet. As for the FFMPEG build, for me, I would rather wait until emby is able to handle the audio for me, I hate switching between apps and extra steps in general lol. Edited August 22, 2021 by lukeoslavia TyPoZ
ebr 16334 Posted August 22, 2021 Posted August 22, 2021 I cannot get it to work in my setup but you guys can test with the next beta version of the Android TV app which will be AC4 aware. Perhaps your system will report support for it. The item will need to be direct playable, though so the .ts versions won't work. 1
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 20 minutes ago, lukeoslavia said: @cayars Yes, we can record it just fine through emby. It saves the video in HEVC and the AC4 audio tracks, however emby doesn't seem to realize they exist in stable and in the beta it sees the tracks but cant deal with them yet. As for the FFMPEG build, for me, I would rather wait until emby is able to handle the audio for me, I hate switching between apps and extra steps in general lol. My thought if there was any interest I could try and script this and allow it's use through Emby's post processing. So basically it would record and kick off a script automatically when the recording is finished. The script would quickly check the .TS recording to see if AC-4 was present and if not abort any conversion. If it found AC-4 it would remux the file to MKV while coping the video and changing the audio to AAC. Being a script it could easily be adapted to delete the original recording or move out for safe storage, etc... Obviously it's best to let Emby handle everything but just thought this might be of use temporarily if anyone really needs to play ATSC 3 records now. Maybe we can wait till the next beta release to see if @softworkz can do anything to improve this first.
lklein 2 Posted August 22, 2021 Author Posted August 22, 2021 Are there any sound bars that would decode it?
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 4 hours ago, clarkss12 said: I would love to try that script..... If I give you a standalone version of ffmpeg compiled for Windows and I give you the command line to use would you be able to run it against a few recordings manually to make sure this will work before we make it a script? I've only tested it on 2 files with AC-4 audio as that's all I have and they were small sample files.
clarkss12 304 Posted August 22, 2021 Posted August 22, 2021 34 minutes ago, cayars said: If I give you a standalone version of ffmpeg compiled for Windows and I give you the command line to use would you be able to run it against a few recordings manually to make sure this will work before we make it a script? I've only tested it on 2 files with AC-4 audio as that's all I have and they were small sample files. I will give it a try.
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 Attached is a windows binary for ffmpeg that includes AC4 decoding. Try this format: ac4ffmpeg -i "c:\convert\atsc3.ts" -vcodec copy -acodec aac "c:\convert\atsc3.mkv" Obviously change those paths to match your input and output file. Let me know how this works. ac4ffmpeg.exe
clarkss12 304 Posted August 22, 2021 Posted August 22, 2021 12 minutes ago, cayars said: Attached is a windows binary for ffmpeg that includes AC4 decoding. Try this format: ac4ffmpeg -i "c:\convert\atsc3.ts" -vcodec copy -acodec aac "c:\convert\atsc3.mkv" Obviously change those paths to match your input and output file. Let me know how this works. ac4ffmpeg.exe 29.42 MB · 1 download I guess that is a little more complicated that I had expected.
emveepee 133 Posted August 22, 2021 Posted August 22, 2021 (edited) Assuming ac4ffmpeg is just the patch from 8349 it doesn't handle the v107.mpeg file anyway because of the silent 5:1 track so the script is even more complicated. Martin Edited August 22, 2021 by emveepee
Carlo 4561 Posted August 22, 2021 Posted August 22, 2021 Here's the v107 file after converting. v107.mkv
clarkss12 304 Posted August 23, 2021 Posted August 23, 2021 17 minutes ago, cayars said: Here's the v107 file after converting. v107.mkv 10.31 MB · 2 downloads That one has audio, but low volume... Can you convert this one?? I will play it on my main system. Thanks. I will learn how to convert those files later in the week. v120.mpeg
Carlo 4561 Posted August 23, 2021 Posted August 23, 2021 ac4ffmpeg -i "v120.mpeg" -vcodec copy -acodec aac "v120.mkv" v120.mkv
emveepee 133 Posted August 23, 2021 Posted August 23, 2021 3 hours ago, cayars said: Here's the v107 file after converting. @cayars are you actually able to play that file with sound? Martin
Carlo 4561 Posted August 23, 2021 Posted August 23, 2021 1 hour ago, emveepee said: @cayars are you actually able to play that file with sound? Martin Yes it plays back with sound as it was converted to AAC. BTW, the next server beta should have this working a lot better. With an early test build I'm able to play back the different AC4 based files that have been posted.
emveepee 133 Posted August 23, 2021 Posted August 23, 2021 Odd v107.mkv won't play with sound for me. v120 is fine. Martin
emveepee 133 Posted August 23, 2021 Posted August 23, 2021 31 minutes ago, cayars said: Will it play in VLC? No it is silent. With your ac4ffmpeg I need to use ac4ffmpeg.exe -i v107.mpeg -map 0:0 -vcodec copy -map 0:a:1 -acodec aac output.ts to get 2 channel sound. The default doesn't transcode the second stereo channel. With the patched ffplay I need to use the "a" key to hear sound on the original source file.
Carlo 4561 Posted August 23, 2021 Posted August 23, 2021 (edited) That's really strange. I just downloaded the v107 version I uploaded earlier and don't get sound either but do on my local copy. Trying it again. v107.mkv Yes you can most definitely expand the command line used to do different things and convert different audio tracks. I was trying to keep it to the absolute simplest command line to make it easy to use if anyone needs it. This likely won't be needed with the next server beta however. Edited August 23, 2021 by cayars
ebr 16334 Posted August 23, 2021 Posted August 23, 2021 If any of you want to try the latest Android TV beta on systems that you think should directly support AC4, you will need to get the item to direct play as the server will not pass the stream in a remux. So, you'll need to enable direct play for TS files and then also probably set the audio option in the app to "Convert unsupported audio to AC3" (I know that may not make sense, but you'll need to do that). Let us know what you find. 1 2
