rljnc 2 Posted January 20, 2022 Posted January 20, 2022 Okay that solved the video issue, so now back to original problems of no audio.
signde 26 Posted January 25, 2022 Posted January 25, 2022 On 1/18/2022 at 4:32 PM, signde said: i did try the latest .64 android tv beta and fire tv beta but can't get passed the loading spinner for either box when tuning ATSC 3 channels. On 1/19/2022 at 9:24 AM, ebr said: That should be corrected with the next beta release of the server. i tried again with the android tv .64 beta on both a fire tv 4k stick and 2019 shield tv pro with the newest beta of the server released today, version 4.7.0.21. at first i thought it wasn't going to work, it spun forever and i believed it to be the same issue so i walked over to my desk to reply in this thread. as i am typing a good 5 minutes later it started playing on its own. during the time it is spinning the dashboard reports direct play but once it actually starts playing, both audio and video are being transcoded. with the stable (.48) android tv app only audio is transcoded. tried other ATSC 3 channels on both devices, same result.
cncb 25 Posted January 26, 2022 Posted January 26, 2022 I am getting similar results with a 2015 Shield TV connected to an Atmos-capable Denon AVR via HDMI. When I play a recording, it transcodes both audio and video stating a conversion reason of "Direct play error". Trying to play a channel live just results in a spinning circle and eventual failure/timeout.
ebr 16335 Posted January 26, 2022 Posted January 26, 2022 What happens with the new server and the standard Android app?
cncb 25 Posted January 26, 2022 Posted January 26, 2022 37 minutes ago, ebr said: What happens with the new server and the standard Android app? I'm not sure exactly what you meant by "standard" app but I tried the non-beta Android TV app and get the same results. I also tried the app on my Pixel 3 and it is able to play Live TV although with transcoding like with the recordings.
ebr 16335 Posted January 26, 2022 Posted January 26, 2022 Hi. I meant sideloading the normal Android app on the TV device.
clarkss12 304 Posted January 26, 2022 Posted January 26, 2022 (edited) To add to this conversation about the ATSC 3 streams. I side loaded the Emby for Android onto my 2017 Nvidia Shield. Using the newest beta server 4.7.0.21 with Emby for Android 3.2.36, a spinning circle and then a black screen. No video playback at all. Of course, on my cellular phone, the ATSC 3 channels play perfectly with audio. Edited January 26, 2022 by clarkss12
signde 26 Posted January 26, 2022 Posted January 26, 2022 1 hour ago, ebr said: What happens with the new server and the standard Android app? Emby for Android 3.2.36 Emby Server 4.7.0.21 2019 Shield TV Pro -> Atmos AVR (have not upgraded to newest shield experience) ATSC 1 channels: works fine ATSC 3 channels: spinner goes away to blank screen. no audio or video. stats for nerds either blank or indicates direct play with HVEC video and 2 channel AC4 audio. server dashboard indicates direct play audio and video. 1
CharlieMurphy 93 Posted January 26, 2022 Posted January 26, 2022 (edited) Same experience. CCwGTV, Beta client without ac4 support. Server 4.7.0.21 2022-01-26 11:23:04.327 Operating System: Linux version 5.11.0-43-generic (buildd@lcy02-amd64-036) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #47~20.04.2 OS/Process: x64/x64 Emby Server version: 4.7.0.21 Operating system: Unix 5.11.0.43 Command Line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 App: AndroidTv 2.0.64g CCwGTV http://emby.url.com/emby/videos/6447501/live.m3u8?DeviceId=0ca3dffc8f0a24f6&MediaSourceId=32bae0cf21fccbead2460f85d9a90327&PlaySessionId=7f97b9d86ac44e9eae940586ac3afdf7&api_key=----&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_32bae0cf21fccbead2460f85d9a90327&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,aac,mp3&VideoBitrate=159616000&AudioBitrate=384000&MaxHeight=2160&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=m4s,ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=AudioCodecNotSupported {"Protocol":"Http","Id":"32bae0cf21fccbead2460f85d9a90327","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/2f998ba2b9fd4b8184b8dababa027e4a/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ContainerStartTimeTicks":551258650890,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_32bae0cf21fccbead2460f85d9a90327","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","StreamStartTimeTicks":551258817780,"TimeBase":"1/90000","VideoRange":"SDR","DisplayTitle":"1080p HEVC","IsInterlaced":false,"BitRate":20000000,"BitDepth":10,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":59.94006,"RealFrameRate":59.94006,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":123,"IsAnamorphic":false},{"Codec":"ac4","CodecTag":"AC-4","Language":"eng","StreamStartTimeTicks":551258817780,"TimeBase":"1/90000","DisplayTitle":"English AC4 5.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","Channels":6,"SampleRate":46034,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"ac4","CodecTag":"AC-4","Language":"spa","StreamStartTimeTicks":551258817780,"TimeBase":"1/90000","DisplayTitle":"Spanish AC4 stereo","DisplayLanguage":"Spanish","IsInterlaced":false,"ChannelLayout":"stereo","Channels":2,"SampleRate":46034,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":20000000,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.0-git LibVLC/3.0.0-git","Referrer":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36"},"ReadAtNativeFramerate":false,"DefaultAudioStreamIndex":1} >>>>>> User policy for User Enable Playback Remuxing: True Enable Video Playback Transcoding: False Enable Audio Playback Transcoding: True >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason Copy video stream >> False False Software Codec VideoInput >> False False Not a hardware decoder VideoOutput >> False False Not a hardware encoder Copy video stream >> False False Software Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p10 yuv420p10 1920x1080 >> /app/emby/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-remux-612ae929-222d-430b-a8bc-da77558fbb52_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -c:v:0 hevc -user_agent "VLC/3.0.0-git LibVLC/3.0.0-git" -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/2f998ba2b9fd4b8184b8dababa027e4a/stream.ts" -map 0:0 -map 0:1 -sn -c:v:0 copy -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 46034 -ac:a:0 6 -metadata:s:a:0 language=eng -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f hls -map_metadata -1 -map_chapters -1 -start_number 0 -hls_time 00:00:03.000 -hls_list_size 0 -hls_base_url hls/D74449/ -hls_segment_filename "/mnt/transcode/transcoding-temp/D74449_%d.m4s" -hls_segment_type fmp4 -hls_fmp4_init_filename "/mnt/transcode/transcoding-temp/D74449_init.mp4" -hls_flags +temp_file "/mnt/transcode/transcoding-temp/D74449.m3u8" 11:23:04.358 ffmpeg version 5.0.0-emby_2022_01_14 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 11:23:04.358 built with gcc 8.3.0 (crosstool-NG 1.24.0) 11:23:04.358 Execution Date: 2022-01-26 11:23:04 11:23:04.478 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/2f998ba2b9fd4b8184b8dababa027e4a/stream.ts': 11:23:04.478 Duration: N/A, start: 55125.865089, bitrate: N/A 11:23:04.478 Program 3 11:23:04.478 Stream #0:0[0x31]: Video: hevc (Main 10) ([36][0][0][0] / 0x0024), yuv420p10le(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], Level 123, 59.94 fps, 59.94 tbr, 90k tbn 11:23:04.478 Stream #0:1[0x32](eng): Audio: ac4 (AC-4 / 0x342D4341), 46034 Hz, 5.1(side), fltp 11:23:04.478 Stream #0:2[0x33](spa): Audio: ac4 (AC-4 / 0x342D4341), 46034 Hz, stereo, fltp 11:23:04.478 Stream #0:3[0x39]: Data: bin_data (STPP / 0x50505453) 11:23:04.488 Stream mapping: 11:23:04.488 Stream #0:0 -> #0:0 (copy) 11:23:04.488 Stream #0:1 -> #0:1 (ac4 (native) -> ac3 (native)) 11:23:04.488 Press [q] to stop, [?] for help 11:23:04.492 [ac3 @ 0x156b580] Specified sample rate 46034 is not supported 11:23:04.492 Error initializing output stream 0:1 -- Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height 11:23:04.494 Conversion failed! 11:23:04.494 Edited January 26, 2022 by CharlieMurphy
Luke 42241 Posted January 26, 2022 Posted January 26, 2022 17 minutes ago, CharlieMurphy said: Same experience. CCwGTV, Beta client without ac4 support. Server 4.7.0.21 11:23:04.358 ffmpeg version 5.0.0-emby_2022_01_14 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 11:23:04.358 built with gcc 8.3.0 (crosstool-NG 1.24.0) 11:23:04.358 Execution Date: 2022-01-26 11:23:04 11:23:04.478 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/2f998ba2b9fd4b8184b8dababa027e4a/stream.ts': 11:23:04.478 Duration: N/A, start: 55125.865089, bitrate: N/A 11:23:04.478 Program 3 11:23:04.478 Stream #0:0[0x31]: Video: hevc (Main 10) ([36][0][0][0] / 0x0024), yuv420p10le(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], Level 123, 59.94 fps, 59.94 tbr, 90k tbn 11:23:04.478 Stream #0:1[0x32](eng): Audio: ac4 (AC-4 / 0x342D4341), 46034 Hz, 5.1(side), fltp 11:23:04.478 Stream #0:2[0x33](spa): Audio: ac4 (AC-4 / 0x342D4341), 46034 Hz, stereo, fltp 11:23:04.478 Stream #0:3[0x39]: Data: bin_data (STPP / 0x50505453) 11:23:04.488 Stream mapping: 11:23:04.488 Stream #0:0 -> #0:0 (copy) 11:23:04.488 Stream #0:1 -> #0:1 (ac4 (native) -> ac3 (native)) 11:23:04.488 Press [q] to stop, [?] for help 11:23:04.492 [ac3 @ 0x156b580] Specified sample rate 46034 is not supported 11:23:04.492 Error initializing output stream 0:1 -- Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height 11:23:04.494 Conversion failed! Hi there, please make sure to attach complete ffmpeg log files. Thanks. 1
Brushfyre 1 Posted January 27, 2022 Posted January 27, 2022 19 hours ago, signde said: Emby for Android 3.2.36 Emby Server 4.7.0.21 2019 Shield TV Pro -> Atmos AVR (have not upgraded to newest shield experience) ATSC 1 channels: works fine ATSC 3 channels: spinner goes away to blank screen. no audio or video. stats for nerds either blank or indicates direct play with HVEC video and 2 channel AC4 audio. server dashboard indicates direct play audio and video. Same exact issue. Updated to Emby Server 4.7.0.21 and channels attempt to load but just get spinner and black screen. Dashboard Stream indicates Direct Play. Will work fine on PC (Stream indicates HLS). ffmpeg-transcode-b0e16eb2-414b-4117-8fd3-e51e23e3595d_1.txt
signde 26 Posted January 28, 2022 Posted January 28, 2022 testing with the new beta server that came out today Emby Server 4.7.0.22 beta Emby Android TV 2.0.64 beta Firestick 4k and Shield TV pro ATSC 3.0 will eventually play but HVEC video is being transcoded to H264 and AC-4 audio is being transcoded to AAC stereo. With the stable Android TV client only the audio is transcoded, HVEC should be direct play. it takes quite a while to play as the dashboard reports attempting direct play audio and video for quite some time before switching to transcode. Emby Server 4.7.0.22 beta Emby Android 3.2.36 beta Shield TV pro ATSC 3.0 no audio/video. Direct play is attempted for quite some time, then for a brief moment audio/video play, then playback stops. Logs from today are zipped and attached. emby-logs.zip 1
MBSki 1115 Posted January 28, 2022 Posted January 28, 2022 Same issue here. I tried with a recording and it'll play back if I have a stereo audio track, but a 5.1 audio track doesn't work. And strangely, the 5.1 audio track doesn't show up on the stable version of Emby server, just on the beta version. Maybe that was a feature enhancements in beta, but I didn't see it anywhere in the release notes. Also, when I do get it to play back using the stereo audio track, the audio is out of sync. It's the same on both the Android TV and standard Emby for Android app.
skinny1962 2 Posted January 28, 2022 Posted January 28, 2022 8 hours ago, mbarylski said: Same issue here. I tried with a recording and it'll play back if I have a stereo audio track, but a 5.1 audio track doesn't work. And strangely, the 5.1 audio track doesn't show up on the stable version of Emby server, just on the beta version. Maybe that was a feature enhancements in beta, but I didn't see it anywhere in the release notes. Also, when I do get it to play back using the stereo audio track, the audio is out of sync. It's the same on both the Android TV and standard Emby for Android app. Same here. No audio on Emby 4.6.7.0 when watching a ATSC 3.0 TV channel. Plays fine in Windows 11 and Windows 10. 1
ebr 16335 Posted January 29, 2022 Posted January 29, 2022 16 hours ago, skinny1962 said: Same here. No audio on Emby 4.6.7.0 when watching a ATSC 3.0 TV channel Hi. That is to be expected because that server version is unaware of AC4 audio.
MBSki 1115 Posted January 29, 2022 Posted January 29, 2022 26 minutes ago, ebr said: Hi. That is to be expected because that server version is unaware of AC4 audio. Ok, but why doesn't the 5.1 track work on the beta version of the server?
CharlieMurphy 93 Posted January 29, 2022 Posted January 29, 2022 It's a work in progress, I think. Beta releases are coming frequently and it feels like this is getting steady attention. When I first started reading about ATSC3 and ffmpeg support for AC4, I wasn't optimistic. It's happening more quickly than I expected, for what it's worth.
signde 26 Posted January 30, 2022 Posted January 30, 2022 i know the samsung app is probably way low on the priority list - tbh i was surprised it even existed. i have a samsung Q90T which per the manual supports AC-4 audio. ATSC 3 does play though the app (version 1.1.06) but the beta server reports the client audio codec is not supported and i get transcoded 2 channel stereo. i see there have been a few app updates since then but samsung app store says this is the latest available. if a beta version exists to fix this i would certainly be willing to try it. Q90T manual: server log embyserver.txt
MBSki 1115 Posted February 2, 2022 Posted February 2, 2022 @ebr Any progress on getting the 5.1 audio track working?
ebr 16335 Posted February 2, 2022 Posted February 2, 2022 3 minutes ago, mbarylski said: @ebr Any progress on getting the 5.1 audio track working? There are still problems remuxing the HEVC video with the beta server so, until that is resolved, the audio is likely to get converted.
MBSki 1115 Posted February 2, 2022 Posted February 2, 2022 1 minute ago, ebr said: There are still problems remuxing the HEVC video with the beta server so, until that is resolved, the audio is likely to get converted. Ok, so is the audio currently getting converted? If it is, should I hear sound or not? Right now I don't hear any sound so just wanted to make sure that's expected even with conversion.
ebr 16335 Posted February 2, 2022 Posted February 2, 2022 2 minutes ago, mbarylski said: Ok, so is the audio currently getting converted? If it is, should I hear sound or not? Right now I don't hear any sound so just wanted to make sure that's expected even with conversion. Can you send or point me to an app log with that exact behavior? My test files are transcoding and converting the audio to AAC.
MBSki 1115 Posted February 2, 2022 Posted February 2, 2022 4 minutes ago, ebr said: Can you send or point me to an app log with that exact behavior? My test files are transcoding and converting the audio to AAC. Got it, I'll test it again a little later and send some logs.
MBSki 1115 Posted February 2, 2022 Posted February 2, 2022 @ebr I tested again and sent the logs. When switching to 5.1 audio it doesn't playback, it just switches back to stereo which has a commentary track on it and is out of sync with the video. I also tried the standard android app and that one wouldn't play back the 5.1 track either. It just popped up the "No compatible streams" message. I'll PM you the info for my logs.
signde 26 Posted February 2, 2022 Posted February 2, 2022 the combination that is working for me on the firestick 4k or shield tv is the latest stable android tv app, version 2.0.48g, and any of the last three beta server versions. it transcodes audio to 2 channel stereo but video is direct play and all the major networks in my market are watchable.
