BillOatman 597 Posted January 11, 2022 Posted January 11, 2022 19 minutes ago, rljnc said: So I do not understand why mine is not working, stats says direct play on video and audio, shows codec as HEVC. This is playing live, have not done any recordings. Best thing probably is to play it and give them the logs. Otherwise they are just guessing.
ebr 16335 Posted January 11, 2022 Posted January 11, 2022 4 minutes ago, BillOatman said: Best thing probably is to play it and give them the logs. Otherwise they are just guessing. Yes, can you please play that item for a few seconds and then follow the instructions to send a log from the app?
ebr 16335 Posted January 11, 2022 Posted January 11, 2022 58 minutes ago, rljnc said: Turned on debug option and sent logs. Quote Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time Thanks.
rljnc 2 Posted January 11, 2022 Posted January 11, 2022 Sent log, was playing ATSC station 117.1 live get no audio, also on this particular station video is distorted, does not happen on other stations, just no audio. Time 11:05 am there about. User rljnc.
ebr 16335 Posted January 11, 2022 Posted January 11, 2022 Okay, you have the beta server but not the beta release of the app. Try installing that on the device.
rljnc 2 Posted January 11, 2022 Posted January 11, 2022 Okay installed the beta app, made no difference.
ebr 16335 Posted January 11, 2022 Posted January 11, 2022 1 hour ago, rljnc said: Okay installed the beta app, made no difference. Can you please repeat and send another log?
rljnc 2 Posted January 11, 2022 Posted January 11, 2022 Sent logs again at 5:27 pm, playing 2 different ATSC 3.0 stations one has distorted video and no audio, the other no audio, user rljnc.
ebr 16335 Posted January 11, 2022 Posted January 11, 2022 34 minutes ago, rljnc said: Sent logs again at 5:27 pm, playing 2 different ATSC 3.0 stations one has distorted video and no audio, the other no audio, user rljnc. Have you disabled transcoding or remuxing in your server settings? Your system is not reporting support for AC4 but the system is not remuxing it like it should.
ebr 16335 Posted January 12, 2022 Posted January 12, 2022 Can I please see the server log that corresponds with that last app log you sent?
ebr 16335 Posted January 13, 2022 Posted January 13, 2022 Is the channel actually playing or is it failing altogether? Looks like a failure on the server: 2022-01-11 17:26:46.012 Error SharedHttpPipelineSource: Give up retries copying live stream http://192.168.1.86:5004/auto/v117.1 *** Error Report *** Version: 4.7.0.19 Command line: /mnt/expand/58f7e9e5-5ca8-4094-b6dc-935a693bb0f3/app/com.emby.embyserver-35CwVSvIWy6Oc5ySFij-nw==/base.apk Operating system: Android 9 (REL) SDK:P BuildId:PPR1.180610.011 Incremental:4079208_2740.7538 Patch-Level: 2021-04-05 Framework: Mono 6.12.0 (2020-02/c633fe92383) 4.0.50524.0 OS/Process: Arm64/Arm64 Runtime: mscorlib.dll Processor count: 4 Data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application path: /mnt/expand/58f7e9e5-5ca8-4094-b6dc-935a693bb0f3/user/0/com.emby.embyserver Fingerprint: NVIDIA/mdarcy/mdarcy:9/PPR1.180610.011/4079208_2740.7538:user/release-keys Model: SHIELD Android TV - NVIDIA/NVIDIA Hardware: mdarcy/mdarcy/darcy/darcy SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.ArgumentOutOfRangeException: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: bytes at System.IO.Pipelines.ThrowHelper.ThrowArgumentOutOfRangeException (System.IO.Pipelines.ExceptionArgument argument) [0x00006] in <6aec29b7da2c4c8e9a4dc1d152ff8904>:0 at System.IO.Pipelines.Pipe.Advance (System.Int32 bytes) [0x0001f] in <6aec29b7da2c4c8e9a4dc1d152ff8904>:0 at System.IO.Pipelines.Pipe+DefaultPipeWriter.Advance (System.Int32 bytes) [0x00000] in <6aec29b7da2c4c8e9a4dc1d152ff8904>:0 at System.IO.Pipelines.PipeWriter.CopyFromAsync (System.IO.Stream source, System.Threading.CancellationToken cancellationToken) [0x000a3] in <6aec29b7da2c4c8e9a4dc1d152ff8904>:0 at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource+<>c__DisplayClass8_0.<StartStreaming>b__0 () [0x003a1] in <02cc6a0dbb1e4f549a11ac95082e4059>:0 Source: mscorlib TargetSite: Void Throw()
rljnc 2 Posted January 13, 2022 Posted January 13, 2022 Channel plays, there are times when I have failures but I can go to another channel and come back and play the channel, but never have audio.
CharlieMurphy 93 Posted January 15, 2022 Posted January 15, 2022 On 1/5/2022 at 3:13 PM, ebr said: @softworkz The current beta server (.19) fails to transcode a live TV stream to the Android TV app when one is needed. I've seen the error above and some others (in other threads). Has this been addressed for the next beta or is more troubleshooting required? Just an update on this. .20 beta server has been behaving the same way. However, this morning I noticed in the server dashboard that my dad was watching one of the local HEVC OTA channels. It was transcoding successfully! I called him to make sure it was actually working, he had sound and video. So he backed out to guide and tried to play the channel again which resulted in the ffmpeg error we normally see. Point being, AC4 transcoding did actually work once out of dozens of attempts. Let me know if my logs would be of any assistance with this. Thanks again, ebr.
signde 26 Posted January 18, 2022 Posted January 18, 2022 i have the .20 beta server connected to a hdhomerun 4k flex. ATSC 3.0 channels seem to be working with transcoded, stereo audio on my 2019 shield tv pro and late model 4k firestick. pretty happy that works, cheers to the folks who got things thus far. both boxes are running the latest stable android apk, v2.0.48. i did try the latest .64 android tv beta and fire tv beta but can't get passed the loading spinner for either box when tuning ATSC 3 channels. a question on the shield pro - should it support AC-4 audio natively without transcoding or is this the best i can hope for at the moment? i read reports on the hdhomerun forums before they started doing cloud transcoding in their app that it could handle the audio for ATSC 3 broadcasts. 1
ebr 16335 Posted January 19, 2022 Posted January 19, 2022 16 hours ago, signde said: i did try the latest .64 android tv beta and fire tv beta but can't get passed the loading spinner for either box when tuning ATSC 3 channels. That should be corrected with the next beta release of the server. 2
ebr 16335 Posted January 19, 2022 Posted January 19, 2022 16 hours ago, signde said: a question on the shield pro - should it support AC-4 audio natively I think it is supposed to work with the device connected directly to an Atmos-capable receiver.
rljnc 2 Posted January 19, 2022 Posted January 19, 2022 Just cannot understand why I cannot get audio, using same kind of setup, all the boxes are checked, what am I missing?
signde 26 Posted January 19, 2022 Posted January 19, 2022 31 minutes ago, ebr said: That should be corrected with the next beta release of the server. 31 minutes ago, ebr said: I think it is supposed to work with the device connected directly to an Atmos-capable receiver. that's encouraging to hear. my shield pro is connected to a dolby atmos AVR. i setup a notification in github for the emby server releases and will try it out as soon as the next one drops and the linuxserver/emby beta docker image is available. 1
rljnc 2 Posted January 19, 2022 Posted January 19, 2022 I am now getting this cannot link executable error, any ideas 2022-01-19 14:24:52.986 Operating System: Android 11 (REL) SDK:30 BuildId:RQ1A.210105.003 Incremental:7094531_2949.3567 Patch-Level: 2021-11-05 OS/Process: Arm64/Arm64 Emby Server version: 4.7.0.20 Operating system: Unix 4.9.141.725 Command Line: /mnt/expand/58f7e9e5-5ca8-4094-b6dc-935a693bb0f3/app/~~GXcftyzmqnmgbzvNAHPBbg==/com.emby.embyserver-dn3raTpwKmbBUBRIvmTTeQ==/base.apk App: Emby Web 4.7.0.20 Firefox Windows >>>>>> User policy for rljnc Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True >>>>>> Affected codecs Encoder Nvidia.h264 Max Bitrate: 48 Mbit/s - Frame Sizes: 48x48...3840x2176 - Width Alignment: 2 - Height Alignment: 2 Max Instances: 32 - Color Formats: YUV420P, YUV420P, NV12, Unknown - Bit Depths: 8 Profiles: High Profile (Level 5.2), Main Profile (Level 5.2), Baseline Profile (Level 5.2) Decoder Nvidia.mpeg2v Max Bitrate: 76 Mbit/s - Frame Sizes: 32x32...1920x1088 - Width Alignment: 2 - Height Alignment: 2 Max Instances: 32 - Color Formats: YUV420P, NV12 - Bit Depths: 8 Profiles: Simple Profile (Main Level), Main Profile (High Level) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'Nvidia.h264' Info Check successful - selecting 'Nvidia.h264' >>>>>> FindVideoDecoder - MediaType: mpeg2video, Mode: Automatic Info Checking: 'Nvidia.mpeg2v' NoMatch The color format (Unknown) is not supported) Info Decoder does not match Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info Deinterlace >> False False Decoder is not a MediaCodec decoder Info ColorConversion >> False False Info VideoOutput >> True True Hardware encoder Info Nvidia.h264 >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info mpeg2video >> - yuv420p yuv420p 1920x1080 >> yadif Info yadif >> - yuv420p yuv420p 1920x1080 >> /mnt/expand/58f7e9e5-5ca8-4094-b6dc-935a693bb0f3/user/0/com.emby.embyserver/files/ffmpeg/ffmpeg -y -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -c:v:0 mpeg2video -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/ad8a77e6e5a54aa6bf38b0a884fb1b72/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all[f1_out0]" -map [f1_out0] -map a:0 -sn -c:v:0 h264_mediacodecndk -b:v:0 15000000 -maxrate:v:0 15000000 -bufsize:v:0 30000000 -profile:v:0 8 -level:v:0 1024 -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -mediacodec_name:v:0 OMX.Nvidia.h264.encoder -c:a:0 copy -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/storage/emulated/0/Android/data/com.emby.embyserver/files/transcoding-temp/133454.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/133454/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 "/storage/emulated/0/Android/data/com.emby.embyserver/files/transcoding-temp/133454_%d.ts" CANNOT LINK EXECUTABLE "/mnt/expand/58f7e9e5-5ca8-4094-b6dc-935a693bb0f3/user/0/com.emby.embyserver/files/ffmpeg/ffmpeg": library "libnativehelper.so" not found: needed by /system/lib64/libmediandk.so in namespace (default)
softworkz 5133 Posted January 19, 2022 Posted January 19, 2022 Have you done something like "Force Install on external/SD" or similar?
rljnc 2 Posted January 19, 2022 Posted January 19, 2022 No it’s installed on a usb drive set as internal storage.
softworkz 5133 Posted January 20, 2022 Posted January 20, 2022 That's what I meant. Please try to install it normally to the internal storage
