mini__me 28 Posted October 9, 2020 Posted October 9, 2020 I'm getting prompted on every single start of the Emby server to allow inbound access through the firewall, despite it being listed and added in the allowed applications. Try looking in there to see if EmbyServer is added? This has only recently started and is pretty annoying. I've tried removing Emby from my login items, removed the entry from the firewall list, shutting down the Mac, booting up the Mac adding EmbyServer manually to the Firewall list, shutting down, starting up, checking EmbyServer is in the allowed list, starting EmbyServer .... and I'm prompted to allow incoming connections!!! Is this because the EmbyServer app isn't signed? @Happy2Play please move my postings from this topic into a new thread because it's not related to this. Thanks.
Luke 42240 Posted October 15, 2020 Posted October 15, 2020 On 10/9/2020 at 4:40 AM, mini__me said: I'm getting prompted on every single start of the Emby server to allow inbound access through the firewall, despite it being listed and added in the allowed applications. Try looking in there to see if EmbyServer is added? This has only recently started and is pretty annoying. I've tried removing Emby from my login items, removed the entry from the firewall list, shutting down the Mac, booting up the Mac adding EmbyServer manually to the Firewall list, shutting down, starting up, checking EmbyServer is in the allowed list, starting EmbyServer .... and I'm prompted to allow incoming connections!!! Is this because the EmbyServer app isn't signed? Hi, that's strange. Did you follow the instructions on the website to drag it into the Applications folder? @levander are you seeing this?
Danig 0 Posted October 16, 2020 Posted October 16, 2020 Hi, Well, my problem is in the title already. At every start of the Emby Server app, I see the dreaded: "Do you want the application Embyserver.app to accept incoming network connections" message popping up. Of course, it's annoying to have to allow that message every time. Does anyone know what to do about it? I've looked in the Emby Settings, but can't find a solution over there. I'm seeing this popup for a couple of weeks now. In the Meanwhile, there was an Emby update, but that didn't resolve the issue. In my Mac Firewall, Embyserver is listed as 'allow incoming connections'. I read about a solution on StackOverflow, but that seems a little dodgy: https://stackoverflow.com/questions/17527700/do-you-want-the-application-to-accept-incoming-network-connection Would it be advisable? Thanks for helping out.. Dan MacOS 10.13.6 / Emby Server 4.5.2.0
levander 97 Posted October 16, 2020 Posted October 16, 2020 On 10/15/2020 at 6:28 PM, Luke said: Hi, that's strange. Did you follow the instructions on the website to drag it into the Applications folder? @levander are you seeing this? No. But I’m not using Catalina.
Luke 42240 Posted October 17, 2020 Posted October 17, 2020 Hi, no I wouldn't do that. We'll look into this. Thanks for reporting.
Luke 42240 Posted October 20, 2020 Posted October 20, 2020 Hi @Danig, can you please try downloading again from the website and installing on top of your existing version? Thanks !
Danig 0 Posted October 20, 2020 Posted October 20, 2020 Superb, no more popups.. thanks a lot! A question though: when there's an update to Emby, should I pass on that, and hold on to this version?
mini__me 28 Posted October 20, 2020 Author Posted October 20, 2020 (edited) On 15/10/2020 at 17:28, Luke said: Hi, that's strange. Did you follow the instructions on the website to drag it into the Applications folder? @levander are you seeing this? Absolutely, been running versions of the server for at least a year now if not longer, running latest macOS Catalina 10.15.7 Edited October 20, 2020 by mini__me
Luke 42240 Posted October 20, 2020 Posted October 20, 2020 You should update when a new version is available. Thanks for the feedback. @mini__me
Luke 42240 Posted October 21, 2020 Posted October 21, 2020 For anyone else who runs into this, I've replaced the 4.5.2 build on our website with a patched version that has a fix for this. You can simply install it on top of your existing version. Thanks. 1
mini__me 28 Posted October 29, 2020 Author Posted October 29, 2020 On 21/10/2020 at 22:22, Luke said: For anyone else who runs into this, I've replaced the 4.5.2 build on our website with a patched version that has a fix for this. You can simply install it on top of your existing version. Thanks. Will give this a go tonight Cheers Luke
Luke 42240 Posted October 29, 2020 Posted October 29, 2020 4 hours ago, mini__me said: Will give this a go tonight Cheers Luke Great, thanks. 1
mini__me 28 Posted October 31, 2020 Author Posted October 31, 2020 Just to confirm the patch fixed my issue
