PenkethBoy 2068 Posted October 20, 2020 Posted October 20, 2020 (edited) emby server down mixes it to stereo in the past i had the downmix to stereo option enabled in the Andorid TV app - so down mix is done on the client end (Shield) Edited October 20, 2020 by PenkethBoy
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 2 minutes ago, OllieP said: please obi one enlighten me You still haven't supplied any logs etc. as yet, so once you have done that, then we can proceed further. 1
Guest Posted October 20, 2020 Posted October 20, 2020 11 minutes ago, PenkethBoy said: emby server down mixes it to stereo in the past i had the downmix to stereo option enabled in the Andorid TV app - so down mix is done on the client end (Shield) Thats not correct. that's MY HOLE POINT the server does not downmix it the client does. "in the past i had the downmix to stereo option enabled in the Andorid TV app" and if thats not there?
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 4 minutes ago, OllieP said: Thats not correct. that's MY HOLE POINT the server does not downmix it the client does. "in the past i had the downmix to stereo option enabled in the Andorid TV app" and if thats not there? 39 minutes ago, CBers said: Also, please confirm that it is indeed the Android TV app you are using and also which version it is. Which version of server are you using as well please? 1
PenkethBoy 2068 Posted October 20, 2020 Posted October 20, 2020 15 minutes ago, OllieP said: Thats not correct. that's MY HOLE POINT the server does not downmix it the client does. "in the past i had the downmix to stereo option enabled in the Andorid TV app" and if thats not there? yes it does - and the downmix to stereo in the ATV app is still there as an option you did install the Emby Android TV version of the app and its actually installed on a Genuine ATV certified hardware - not some cheap ass chinese knock off?
Guest Posted October 20, 2020 Posted October 20, 2020 29 minutes ago, CBers said: You still haven't supplied any logs etc. as yet, so once you have done that, then we can proceed further. my android phone certainly is not a cheep Chinese knock off. so the logs are as follows. from what i can see my phone played a 5.1 audio stream when it only has 1 single speaker. the logs possibly show diffrent emby.7z
Guest Posted October 20, 2020 Posted October 20, 2020 Just now, OllieP said: my android phone certainly is not a cheep Chinese knock off. so the logs are as follows. at 10.28 my phone started a vid and direct played from what i can see my phone played a 5.1 audio stream when it only has 1 single speaker. the logs possibly show diffrent emby.7z 5.4 MB · 0 downloads
Guest Posted October 20, 2020 Posted October 20, 2020 9 minutes ago, PenkethBoy said: yes it does - and the downmix to stereo in the ATV app is still there as an option you did install the Emby Android TV version of the app and its actually installed on a Genuine ATV certified hardware - not some cheap ass chinese knock off? My Chinese knock of installed Netflix last night and played a film 1080 p in stereo perfectly fine!
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 8 minutes ago, OllieP said: my android phone certainly is not a cheep Chinese knock off. so the logs are as follows. from what i can see my phone played a 5.1 audio stream when it only has 1 single speaker. the logs possibly show diffrent emby.7z 5.4 MB · 1 download And you submitted the in-app logs from the Android TV app to @ebr to look at ? Looks like a lot of transcoding and/or remuxing going on on the server (remuxing is just converting the audio, not the video). For example on your Fire TV device whilst watching "Star.Wars.Episode.IX.The.Rise.of.Skywalker.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv": App: AndroidTv 1.8.29a Mr's 2nd Fire TV 19:13:14.732 Stream mapping: 19:13:14.732 Stream #0:0 -> #0:0 (copy) 19:13:14.732 Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native)) 19:13:14.732 Stream #0:9 -> #1:0 (subrip (srt) -> webvtt (native)) 19:13:14.732 Stream #0:0 -> #1:1 (copy) The server was copying the video but converting the audio, TrueHD to AC3. Also converting the subtitles, SRT to WEBVTT. What were the issues you experienced whilst playing that ? Also, AndroidTv 1.8.29a is a beta version, for which you are a long way behind - current beta is 1.8.42. It might be worth updating the app and trying again. When an issue arise, please send in-app logs. You need to turn on the DEBUG options within the app to be able to send the logs. Thanks. 1
Guest Posted October 20, 2020 Posted October 20, 2020 1 minute ago, CBers said: And you submitted the in-app logs from the Android TV app to @ebr to look at ? Looks like a lot of transcoding and/or remuxing going on on the server (remuxing is just converting the audio, not the video). For example on your Fire TV device whilst watching "Star.Wars.Episode.IX.The.Rise.of.Skywalker.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv": App: AndroidTv 1.8.29a Mr's 2nd Fire TV 19:13:14.732 Stream mapping: 19:13:14.732 Stream #0:0 -> #0:0 (copy) 19:13:14.732 Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native)) 19:13:14.732 Stream #0:9 -> #1:0 (subrip (srt) -> webvtt (native)) 19:13:14.732 Stream #0:0 -> #1:1 (copy) The server was copying the video but converting the audio, TrueHD to AC3. Also converting the subtitles, SRT to WEBVTT. What were the issues you experienced whilst playing that ? Also, AndroidTv 1.8.29a is a beta version, for which you are a long way behind - current beta is 1.8.42. It might be worth updating the app and trying again. When an issue arise, please send in-app logs. You need to turn on the DEBUG options within the app to be able to send the logs. Thanks. is that log possibly because i have changed the audio setting on the app when in that video to make it play correctly? can you see the one from 10:28 this morning? did thatdo the same?
PenkethBoy 2068 Posted October 20, 2020 Posted October 20, 2020 Netflix is irrelevant if it is indeed a Chinese Knock off then thats probably the root of all your problems 1
Guest Posted October 20, 2020 Posted October 20, 2020 4 minutes ago, CBers said: And you submitted the in-app logs from the Android TV app to @ebr to look at ? Looks like a lot of transcoding and/or remuxing going on on the server (remuxing is just converting the audio, not the video). For example on your Fire TV device whilst watching "Star.Wars.Episode.IX.The.Rise.of.Skywalker.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv": App: AndroidTv 1.8.29a Mr's 2nd Fire TV 19:13:14.732 Stream mapping: 19:13:14.732 Stream #0:0 -> #0:0 (copy) 19:13:14.732 Stream #0:1 -> #0:1 (truehd (native) -> ac3 (native)) 19:13:14.732 Stream #0:9 -> #1:0 (subrip (srt) -> webvtt (native)) 19:13:14.732 Stream #0:0 -> #1:1 (copy) The server was copying the video but converting the audio, TrueHD to AC3. Also converting the subtitles, SRT to WEBVTT. What were the issues you experienced whilst playing that ? Also, AndroidTv 1.8.29a is a beta version, for which you are a long way behind - current beta is 1.8.42. It might be worth updating the app and trying again. When an issue arise, please send in-app logs. You need to turn on the DEBUG options within the app to be able to send the logs. Thanks. as for the app that was download from the store 3 days ago?
Guest Posted October 20, 2020 Posted October 20, 2020 Please looking through all the logs can show different results because i constantly fifing around trying to make it play ( which i don't believe i should do) my test is 10.28 i played band of brothers on my mobile phone. All legit with the app that downloaded of the play store 3 days ago when i set this up. my phone god bless it has one speaker, two if i plug headphones in. 5.1 audio on that device would not be correct can we at least agree on that, what happened in the logs and i will hold my piece
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 3 minutes ago, OllieP said: is that log possibly because i have changed the audio setting on the app when in that video to make it play correctly? can you see the one from 10:28 this morning? did thatdo the same? What did you watch at 10:28 this morning ? 1 minute ago, OllieP said: as for the app that was download from the store 3 days ago? There is a lag in the Google Store recently, but you can sideload, if you know how to do that, by downloading the APK from the Release Notes thread, first post. 1
Guest Posted October 20, 2020 Posted October 20, 2020 Just now, CBers said: What did you watch at 10:28 this morning ? There is a lag in the Google Store recently, but you can sideload, if you know how to do that, by downloading the APK from the Release Notes thread, first post. band of brothers
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 1 minute ago, OllieP said: my test is 10.28 i played band of brothers on my mobile phone That's not the ANdroid TV app though is it. Your issue is using that app, so you need to stay consistent with the app your using. 1
Guest Posted October 20, 2020 Posted October 20, 2020 Just now, CBers said: That's not the ANdroid TV app though is it. Your issue is using that app, so you need to stay consistent with the app your using. what difference does it make.
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 Just now, OllieP said: what difference does it make. Because you're trying to compare apples with oranges and it ain't gonna work. 1
Guest Posted October 20, 2020 Posted October 20, 2020 ok we will only use the android app from now on. because then we can repeat the whole process on all the devices.
Guest Posted October 20, 2020 Posted October 20, 2020 ok so at 10.28 what happened and did the server and client reliably work out that 5.1 audio is not right for this device
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 1 minute ago, OllieP said: ok we will only use the android app from now on. because then we can repeat the whole process on all the devices. OK. Play a video from your server, nit Live TV for the time being, and when/if an issue arises, send the in-app logs via the option within the app (debug needs to be enabled before playback starts). Then post here the time and Emby user in use in the app so that @ebr can make sure he's looking at the correct log. 1
CBers 7556 Posted October 20, 2020 Posted October 20, 2020 Just now, OllieP said: i just have mate? Just have what ? 1
PenkethBoy 2068 Posted October 20, 2020 Posted October 20, 2020 Only use the ATV app on you box connected to the tv - not anything else play BB again then upload the log file from emby and the ffmpeg log file also in the log directory for that playback attempt
