skank 85 Posted October 15, 2020 Posted October 15, 2020 I have the kodi netflix addon using embruary skin, i made a custom hub for netflix and some widgets The widgets are pointing to the neflix addon parts: - populair - top 10 - Trending - Netflix originals However when i hit the widget to play, nothing happens? Someone pls help? Heres the log https://paste.kodi.tv/pemoxodida
skank 85 Posted October 15, 2020 Author Posted October 15, 2020 I tried with other skin , and there it works, so probably skin related
emdubya77 35 Posted October 17, 2020 Posted October 17, 2020 (edited) [deleted] Edited July 6, 2022 by emdubya77
skank 85 Posted October 18, 2020 Author Posted October 18, 2020 Its not an addon fault cause it works with other skins So its a skin issue, the only one who can fix this is the skin developer, so thats to point here, no? Pity nobody from emby reacts
emdubya77 35 Posted October 18, 2020 Posted October 18, 2020 (edited) [deleted] Edited July 6, 2022 by emdubya77
skank 85 Posted October 18, 2020 Author Posted October 18, 2020 I did post in the addon section of the kodi forum, they pointed me to here
neik 874 Posted October 18, 2020 Posted October 18, 2020 Yeah, well Emby has nothing to do with the Netflix working or not. No matter if it's a skin (also not an Emby issue btw.) issue or not. @sualfred is the developer of the skin iirc, so maybe he can help you.
