Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 Hi, No need to do anything in Emby if using MCEBuddy. Just set the watch folder in MCEBuddy and you should be good.
jriker1 21 Posted September 26, 2021 Posted September 26, 2021 2 hours ago, cayars said: Hi, No need to do anything in Emby if using MCEBuddy. Just set the watch folder in MCEBuddy and you should be good. Yeah, I'm doing that now for another purpose with MCEBuddy however challenge is knowing when the file is done downloading. Never used Emby to record live tv but if it writes the file in the same folder as the destination then need to set delays before processing the files. Depending on the potential length of the file recording, have needed in the past to set processing to wait until at least a few hours after the last modified date of the file.
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 You shouldn't need to change anything as MCEBuddy can handle files being recorded.
Oingofan 0 Posted September 30, 2021 Posted September 30, 2021 So...it's been awhile on talk about incorporating commercial marking/skip into Emby. Is it being worked on or is it a pipedream for now? In the meantime, is MCEBuddy the best solution?
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 Yes, for now MCEBuddy is a great solution as it has a lot of features you can adjust including conversions besides just cutting.
