Happy2Play 9814 Posted October 17, 2020 Posted October 17, 2020 Just now, chuga said: not sure how to rotate logs - heard about that but I do not see the option anywhere in docker settings. I can restart docker and play/top LiveTV if that would help? Wouldn't think Docker would be any different, but you should see the option on Dashboard-Scheduled Tasks "Rotate log file".
chuga 4 Posted October 17, 2020 Author Posted October 17, 2020 OK I restarted docker (it cleared temp files) after restarted I opened emby on Roku and started live TV I exited via home I entered emby again I exited by hitting'back' a few times and selecting 'exit emby' i restarted emby see attached log... thanks embyserver.txt
Happy2Play 9814 Posted October 17, 2020 Posted October 17, 2020 (edited) Clean up appears to be happening correctly in the log. Both logs on specific playback session. 2020-10-17 18:12:52.411 Info HttpServer: HTTP POST http://192.168.1.192:8096/emby/Sessions/Playing/Stopped. UserAgent: Roku/DVP-9.30 (469.30E04194A) 2020-10-17 18:12:52.417 Info HttpServer: HTTP Response 200 to 192.168.1.104. Time: 31ms. http://192.168.1.192:8096/emby/livetv/programs?userId=14a223d7cdde46ce814bd07123582e9a&fields=overview,channelInfo,IsHD&sortBy=StartDate&EnableImageTypes=Primary,Thumb&maxStartDate=2020-10-18T00%3A00%3A00Z&minEndDate=2020-10-17T22%3A00%3A00Z&channelIds=523223%2C523224%2C523210%2C523211%2C523212. ConnectionId: 0HM3F0HNETT3F 2020-10-17 18:12:52.423 Debug App: ReportPlaybackStopped PlaySessionId: 26043ce31c3d4b89a0eb6cb932ddb787 2020-10-17 18:12:52.423 Debug EncodingManager: KillTranscodingJob - JobId 223eefee-41a8-45f4-add6-2938a559c642 PlaySessionId 26043ce31c3d4b89a0eb6cb932ddb787. Killing transcoding 2020-10-17 18:12:52.445 Info App: ProcessRun 'StreamTranscode 223eef': Stopping ffmpeg process with q command for /config/transcoding-temp/84BFF8_0.ts 2020-10-17 18:12:52.615 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 955360ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/8e73b744190b48eeb02ff7fda5198b2d/stream.ts. ConnectionId: 0HM3F0HNETT09 2020-10-17 18:12:52.831 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-remux-223eefee-41a8-45f4-add6-2938a559c642_1graph.txt 2020-10-17 18:12:52.832 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2020-10-17 18:12:52.832 Info App: AppendExtraLogData - File Deleted 2020-10-17 18:12:52.861 Info App: ProcessRun 'StreamTranscode 223eef' Process exited with code 0 2020-10-17 18:12:52.875 Debug App: ProcessRun 'StreamTranscode 223eef': WaitForExitAsync took 390ms 2020-10-17 18:12:52.875 Debug EncodingManager: Deleting partial stream file(s) /config/transcoding-temp/84BFF8.m3u8 2020-10-17 18:12:52.875 Info SessionManager: Playback stopped reported by app Roku SG 4.0.4 playing ABC. Stopped at 945000 ms 2020-10-17 18:12:52.881 Info MediaSourceManager: Live stream native_4dc30a1bd515d74f0a04076ded64dcfe_23a5b6091c92818ffdc6638a5121cab0 consumer count is now 1 2020-10-17 18:12:52.881 Info HttpServer: HTTP Response 204 to 192.168.1.104. Time: 470ms. http://192.168.1.192:8096/emby/Sessions/Playing/Stopped. ConnectionId: 0HM3F0HNETSVU Edited October 17, 2020 by Happy2Play
chuga 4 Posted October 18, 2020 Author Posted October 18, 2020 I let Live TV play for awhile (since last post) in ~30minutes it created 630 temp files taking up 7gb of space. I exited via 'home' button a few minutes ago. Since then I have been watching the transcoding folder and not only did it not empty, but it keeps growing. I understand now that 'home' does not clear the temp folder but it just keeps running all night until my cache drive fills up and docker crashes... thanks embyserver.txt
Happy2Play 9814 Posted October 18, 2020 Posted October 18, 2020 (edited) 6 minutes ago, chuga said: I let Live TV play for awhile (since last post) in ~30minutes it created 630 temp files taking up 7gb of space. I exited via 'home' button a few minutes ago. Since then I have been watching the transcoding folder and not only did it not empty, but it keeps growing. I understand now that 'home' does not clear the temp folder but it just keeps running all night until my cache drive fills up and docker crashes... thanks embyserver.txt 9.05 MB · 0 downloads It will continue to grow until the "Are you still watching" setting is caught and then stop this runaway session (assuming enabled). As speechles mentioned this is a defect within the Roku itself. Edited October 18, 2020 by Happy2Play
chuga 4 Posted October 18, 2020 Author Posted October 18, 2020 gotcha - OK I'll re-enable 'are you still watching' thanks for the help
