matsonjr 6 Posted October 12, 2020 Posted October 12, 2020 So it is my first post...most things I seem to be getting figured out on a fresh install of everything. I am a long time user of WMC. It combined with my ceton card is the only one that handles the DRM stuff. So, I'm trying to update things so I can use ROKU and smartTV apps for viewing. Most things I am getting figured out pretty easily. HOWEVER, I have slugs of old programs recorded using WMC. When I try to view in Emby using the serverWMC plug-in or the livetv area under recording, I get a messed up aspect ratio on a lot of programs. SD I think is all of them. If regular old aspect ratio is 4:3, it looks like is displaying 2:3. More to report is, this issue seems to be ROKU. On my Samsung TV, android app and browser, the aspect ratio seems correct. Also, last night, before installing EMBY, I used Jellyfin and used the Jellyfin app on ROKU with a pretty much identical set up and the aspect ratio there was correct. So, is this a setting problem or a problem with the ROKU app? Thanks-
Luke 42234 Posted October 12, 2020 Posted October 12, 2020 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
matsonjr 6 Posted October 12, 2020 Author Posted October 12, 2020 Attached is a picture of good ol Knight Rider...recorded in 480i
matsonjr 6 Posted October 12, 2020 Author Posted October 12, 2020 Log files of my old show attached. embyserver.txt ffmpeg-remux-d6c5dcf1-7143-4325-9a84-1151536695ce_1.txt
matsonjr 6 Posted October 12, 2020 Author Posted October 12, 2020 Just another thought as I am thinking about it as I work towards putting this all together with my old WMC machine plugging along. Then a new machine with Emby. Scenario #1 (this one I know the flow) Recorded TV is housed on WMC. So when Emby calls for TV, it flows from WMC to Emby to extender. Scenario #2 (how does it work) Recorded TV is housed on Emby So when Emby calls for recorded TV how is the flow: A) WMC calls for media, gets it from Emby only to send it back to Emby to send it to extender or b) WMC tells Emby "it is over there, get it yourself" Just trying to figure out the best place to store my recorded TV.
matsonjr 6 Posted October 14, 2020 Author Posted October 14, 2020 On 10/11/2020 at 8:39 PM, Luke said: Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks ! Any luck figuring out my funky videos?
Luke 42234 Posted December 16, 2020 Posted December 16, 2020 hi @matsonjr apologies for the delay. The answer is we're trying to stream the original video as-is, and the Roku is not rendering it correctly. What we need to do is force a full conversion of the video into a compatible format. If you install Emby Server 4.5.4 then it should do this now. Thanks.
speechles 2062 Posted December 16, 2020 Posted December 16, 2020 (edited) On the Roku if you press DOWN while video plays this open the OSD for the video player. On the OSD will be a COG/GEAR. Click that and it will open the playback menu. On the playback menu will be on option called "Use Playback Correction" and all you should need to do is press that once. That should allow you to view the video correctly and force a full transcode rather than stream copy if it is directstream/remux. Edited December 16, 2020 by speechles
