No channels or live TV using Locast2Plex
I installed Locast2Plex with Docker Container. I was able to add it as a source in Plex and generate a TV guide in Plex, and though there is a guide, it doesn't play any channel, it gives a playback error. In Emby, I was able to add it as a TV Source, and added TV guide, but there are no channels that appear, and thus no playback.
Using Emby server 4.5.2.0 through Chrome browser in Windows 10.
Thank you
Edited by Josh-Emby
Thank you
I figured it out... I had in the config.ini file my ip and port (ie: 127.0.0.1:6077), and when I tried to and it just needed the ip, all works now.
Thanks for the feedback.
