reneboulard 35 Posted October 11, 2020 Posted October 11, 2020 I am trying to make a Post-Processing script work on a rasperrypi4b. The script work on my main server Ubuntu 20.4. x64 However it does not on the RaspberryPI4 running arm64 Ubuntu. I can run the script manually on the command line as emby user. I can run the script as a cronjob as emby user. but when the post-processing is started from emby server it give the following erreur. 2020-10-11 06:36:01.050 Info LiveTV: Recording post-processing script completed with exit code 139 Any suggestions will help!
PenkethBoy 2068 Posted October 11, 2020 Posted October 11, 2020 the 139 is coming from whatever interpreter you are using to execute the script - emby is just getting that returned its not an emby problem - use google to find what it means i suspect emby is not running under emby user/or you have a typo or some version compatibility perhaps find out what 139 means and you can go from there.
reneboulard 35 Posted October 11, 2020 Author Posted October 11, 2020 1 hour ago, PenkethBoy said: the 139 is coming from whatever interpreter you are using to execute the script - emby is just getting that returned its not an emby problem - use google to find what it means i suspect emby is not running under emby user/or you have a typo or some version compatibility perhaps find out what 139 means and you can go from there. Thank you for the quick answer, error 139 means a signal for memory access violation, trying to read or write from/to a memory area that your process does not have access to. Since the Post-Processing script run fine alone, I do not think it is the script fault. emby-serveur run under emby user. The set up is standard. I also have the same error when I try to run a Post-Processing script on a Armv7 setup on Raspian I will investigate further, see what is the different between the x64 vs arm64 setup, since all in fine and the X64 system.
Q-Droid 1011 Posted October 12, 2020 Posted October 12, 2020 Have you accounted for the ENV settings when the script runs from the Emby server vs. command line? Emby sets its own values. I don't know what RPi would have set but this is an example from CentOS. Any DRIVERS values and LD_LIBRARY_PATH are often key. AMDGPU_IDS=/opt/emby-server/share/libdrm/amdgpu.ids EMBY_DATA=/var/lib/emby FONTCONFIG_PATH=/opt/emby-server/etc/fonts HOME=/var/lib/emby HOSTTYPE=x86_64 LD_LIBRARY_PATH=/opt/emby-server/lib:/opt/emby-server/lib/samba LIBVA_DRIVERS_PATH=/opt/emby-server/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri: SSL_CERT_FILE=/opt/emby-server/etc/ssl/certs/ca-certificates.crt
reneboulard 35 Posted October 12, 2020 Author Posted October 12, 2020 3 hours ago, Q-Droid said: Have you accounted for the ENV settings when the script runs from the Emby server vs. command line? Emby sets its own values. I don't know what RPi would have set but this is an example from CentOS. Any DRIVERS values and LD_LIBRARY_PATH are often key. AMDGPU_IDS=/opt/emby-server/share/libdrm/amdgpu.ids EMBY_DATA=/var/lib/emby FONTCONFIG_PATH=/opt/emby-server/etc/fonts HOME=/var/lib/emby HOSTTYPE=x86_64 LD_LIBRARY_PATH=/opt/emby-server/lib:/opt/emby-server/lib/samba LIBVA_DRIVERS_PATH=/opt/emby-server/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri: SSL_CERT_FILE=/opt/emby-server/etc/ssl/certs/ca-certificates.crt Thank you for the suggestion. I try a one line bash script as post-processing but I still get the same result - Emby report error 139. I do not think the problem is the script or related to the ENV settings. I am using the crontab for emby user as a work around, a task is started every 30 minutes and if it find a new .ts file, it check to make sure the recording is finished and if so start the postprocessing script on the file, it is not very elegant but it work.
