Guest Posted October 9, 2020 Posted October 9, 2020 Looking for the location of where Emby copies the image for the actual Library itself when you do Edit Images and add an image for the Library. Thanks.
Solution Happy2Play 9811 Posted October 9, 2020 Solution Posted October 9, 2020 If a custom library image is applied it will be in \Emby-Server\programdata\root\default\specific library. If it is a server generated dynamic image it will be in \Emby-Server\programdata\metadata\library\xx\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx folder (what ever ID the server assigned it. The parentid in the url when you enter that library should be the folder number you will find the image in. Location path will vary depending on platform. Look at Dashboard Paths or Program data path in your log.
Guest Posted October 9, 2020 Posted October 9, 2020 30 minutes ago, Happy2Play said: If a custom library image is applied it will be in \Emby-Server\programdata\root\default\specific library. If it is a server generated dynamic image it will be in \Emby-Server\programdata\metadata\library\xx\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx folder (what ever ID the server assigned it. The parentid in the url when you enter that library should be the folder number you will find the image in. Location path will vary depending on platform. Look at Dashboard Paths or Program data path in your log. Thanks for the reply. I should probably know this but I don't. What's the root folder for that path?
Happy2Play 9811 Posted October 9, 2020 Posted October 9, 2020 6 minutes ago, argo33 said: Thanks for the reply. I should probably know this but I don't. What's the root folder for that path? Looking at someone else's log Data path: /Users/{USER}/.config/emby-server
Guest Posted October 9, 2020 Posted October 9, 2020 12 minutes ago, Happy2Play said: Looking at someone else's log Data path: /Users/{USER}/.config/emby-server Perfect got it. Thank you! Perfect got it. Thank you!
