hamrtyme 0 Posted October 8, 2020 Posted October 8, 2020 have emby premier and now my android ox wont play?
Luke 42246 Posted October 8, 2020 Posted October 8, 2020 Hi there, what happens when you try to play?
hamrtyme 0 Posted October 8, 2020 Author Posted October 8, 2020 I've had emby premiere since February
ebr 16338 Posted October 8, 2020 Posted October 8, 2020 Hi. I don't see a Premiere key on this email address. Is your key installed properly in your server? Are you connected to that server when this problem occurs?
hamrtyme 0 Posted October 8, 2020 Author Posted October 8, 2020 It would have been a different email. It works on all my other devices just not the box
ebr 16338 Posted October 8, 2020 Posted October 8, 2020 Can that device get out to the internet? Something may be blocking that particular device. Can you confirm that you are connected to the server with the Premiere key at the time?
