Luke 42203 Posted October 15, 2020 Posted October 15, 2020 27 minutes ago, LeidenSpai said: I just tried to rename TV Mi Stick to Mi Stick (using the menu itself, because from Home it is not possible). And nothing, the same thing keeps happening: "ready to cast" and the emby logo appear on the TV, but if from the mobile you give it to send, it is not even seen on the mobile that is sent- Can you try it again? thanks.
LeidenSpain 33 Posted October 15, 2020 Posted October 15, 2020 1 hour ago, Luke said: Can you try it again? thanks. Exactly the same. Good night
Luke 42203 Posted October 17, 2020 Posted October 17, 2020 On 10/15/2020 at 5:55 PM, LeidenSpai said: I just tried to rename TV Mi Stick to Mi Stick (using the menu itself, because from Home it is not possible). And nothing, the same thing keeps happening: "ready to cast" and the emby logo appear on the TV, but if from the mobile you give it to send, it is not even seen on the mobile that is sent- Ok i found an issue related to special characters in the Chromecast device name. Please give it another try. Thanks !
LeidenSpain 33 Posted October 17, 2020 Posted October 17, 2020 9 hours ago, Luke said: Ok i found an issue related to special characters in the Chromecast device name. Please give it another try. Thanks ! The same
Luke 42203 Posted October 17, 2020 Posted October 17, 2020 3 hours ago, LeidenSpai said: The same What is your Chromecast name?
LeidenSpain 33 Posted October 17, 2020 Posted October 17, 2020 31 minutes ago, Luke said: What is your Chromecast name? The one I'm using now for testing "My Stick" The MiBox S I do not remember, and the Chromecast, well "Chromecast"
Luke 42203 Posted October 18, 2020 Posted October 18, 2020 23 hours ago, LeidenSpai said: The one I'm using now for testing "My Stick" The MiBox S I do not remember, and the Chromecast, well "Chromecast" Can you please attach the emby server log? thanks.
LeidenSpain 33 Posted October 20, 2020 Posted October 20, 2020 (edited) On 10/18/2020 at 6:31 PM, Luke said: Can you please attach the emby server log? thanks. 12:06 - I have tried to send a photo that is locally on the server VID_20201020_120722.mp4 embyserver.txt embyserver-63738748800.txt Edited October 20, 2020 by LeidenSpai
Luke 42203 Posted October 21, 2020 Posted October 21, 2020 19 hours ago, LeidenSpai said: 12:06 - I have tried to send a photo that is locally on the server VID_20201020_120722.mp4 9.49 MB · 0 downloads embyserver.txt 329.78 kB · 0 downloads embyserver-63738748800.txt 34.39 kB · 0 downloads What about video playback, can you provide a log example of that? Thanks.
LeidenSpain 33 Posted October 22, 2020 Posted October 22, 2020 On 10/21/2020 at 7:14 AM, Luke said: What about video playback, can you provide a log example of that? Thanks. 19:03 i try to play a local video from the server I see there is a -2H on the timeline embyserver.txt
Luke 42203 Posted October 24, 2020 Posted October 24, 2020 On 10/22/2020 at 1:09 PM, LeidenSpai said: 19:03 i try to play a local video from the server I see there is a -2H on the timeline embyserver.txt 634.12 kB · 0 downloads There's no communications here from your Chromecast device. This means that although your casting device can reach your Chromecast receiver, your Chromecast receiver can't reach your Emby Server. Does your Emby Server display the correct local and remote addresses?
LeidenSpain 33 Posted October 24, 2020 Posted October 24, 2020 3 hours ago, Luke said: There's no communications here from your Chromecast device. This means that although your casting device can reach your Chromecast receiver, your Chromecast receiver can't reach your Emby Server. Does your Emby Server display the correct local and remote addresses? I just saw that in the server data the public address was correct, but the private one was the internal IP of the docker, not the server's Well that was it, now it works for me I was looking at the address that the container creates (127.0.0.3) In the server settings I have indicated the real address of the equipment, and it works. thank you very much as always for the help
Luke 42203 Posted October 24, 2020 Posted October 24, 2020 12 minutes ago, LeidenSpai said: I just saw that in the server data the public address was correct, but the private one was the internal IP of the docker, not the server's Well that was it, now it works for me I was looking at the address that the container creates (127.0.0.3) In the server settings I have indicated the real address of the equipment, and it works. thank you very much as always for the help Thanks for the feedback.
mdoliver 0 Posted May 29, 2021 Posted May 29, 2021 Hi all Hopefully posting in this thread is okay. I have a very similar issue with casting. Emby 4.6.1.0 running externally using custom SSL cert. Chromecast Ultra Attached Emby log Attempting to cast on local network via Chrome browser page is unsuccessful. Attempting to cast locally via Chrome Emby app for Android is successful All attempts at casting remotely (https required) fail with "Ready to cast" message permanently displayed on casted device In the attached log user Dan at 07:09:44.373) plays media and attempts to cast. Casting device name has been changed to just "TV" local and remote connection addresses are correct in Emby dashboard Any help/suggestions would be greatly appreciated. embyserver.txt
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 Chromecast on the browser requires a secure context. That means you either need to be using the web app on localhost or an https address. And then for #3, most likely the Chromecast receiver is rejecting your server certificate. There is no way for us to override this, so if you're going to setup ssl for remote connections, then your certificate has to come from a provider that Chromecast will trust.
mdoliver 0 Posted May 30, 2021 Posted May 30, 2021 Thanks Luke, I disabled SSL on my site and casting worked. Do you know if the Chromecast will support a Lets Encrypt free SSL cert?
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 55 minutes ago, mdoliver said: Thanks Luke, I disabled SSL on my site and casting worked. Do you know if the Chromecast will support a Lets Encrypt free SSL cert? I've tested it successfully in the past but these rules seem to constantly change so I think you'll just have to try it.
