SonS3ood 0 Posted October 5, 2020 Posted October 5, 2020 Hello. I have a problem with arabic subtitle when I chose it
Luke 42239 Posted October 5, 2020 Posted October 5, 2020 HI there, what exactly is the problem? The encoding?
SonS3ood 0 Posted October 6, 2020 Author Posted October 6, 2020 (edited) The letters are not arabic . Edited October 6, 2020 by SonS3ood
SonS3ood 0 Posted October 6, 2020 Author Posted October 6, 2020 10 minutes ago, Luke said: Where did you get the subtitles from? from subcene and it's SRT file.
SonS3ood 0 Posted October 6, 2020 Author Posted October 6, 2020 I belive have the same problem that I have.
Abobader 3485 Posted October 6, 2020 Posted October 6, 2020 Hi, Normally that when the creation of that file using none UTF-8 encode. Download (it free) Subtitle Edit and open that file and it will show you what encode it is. You can convert it to UTF-8 as well. My best
SonS3ood 0 Posted October 6, 2020 Author Posted October 6, 2020 3 minutes ago, Abobader said: Hi, Normally that when the creation of that file using none UTF-8 encode. Download (it free) Subtitle Edit and open that file and it will show you what encode it is. You can convert it to UTF-8 as well. My best how I can convert it to UTF-8?
SonS3ood 0 Posted October 6, 2020 Author Posted October 6, 2020 2 hours ago, Luke said: How did you name the subtitle file? same name as the episode.
Luke 42239 Posted October 6, 2020 Posted October 6, 2020 3 minutes ago, SonS3ood said: same name as the episode. Can you try renaming it to include the language as outlined in our subtitle naming guide? https://support.emby.media/support/solutions/articles/44001159160-subtitles Then run a library scan and try again. Thanks.
