icedragonslair 10 Posted October 10, 2013 Posted October 10, 2013 Server works perfect for what I am using it for and I would love to spend 2 days in a row without an update coming into the middle of our prime time evening (when we sit down to watch tv). Under server tasks, I have tried deleting the application update triggers and the plugin update triggers as well, but it still broke in today and had to restart due to an update (that it wasn't even supposed to check for?). So what am I missing here? Thanks, Ice
ebr 16354 Posted October 10, 2013 Posted October 10, 2013 Nothing should "break in" while you are viewing something. Can you explain exactly what it is that is happening and what you want to prevent?
CBers 7571 Posted October 10, 2013 Posted October 10, 2013 You don't have to do the update straight away, just when you're ready to do so.
Luke 42287 Posted October 10, 2013 Posted October 10, 2013 This is not normal. Typically when we post a new server update, there are 1-2 follow-ups containing things we may have missed during the testing process. Now that that's over with, it'll be another few weeks before the next version.
Tikuf 663 Posted October 10, 2013 Posted October 10, 2013 Unless of course you are on dev update as the builds are far more frequent due to us testing. I strongly advise if you are infact on dev update you switch it to beta.
icedragonslair 10 Posted October 27, 2013 Author Posted October 27, 2013 Uninstalled/reinstalled and all seems fine now as far as the updates are concerned. Still on Dev and seems to be better, will give it some more time
Luke 42287 Posted October 27, 2013 Posted October 27, 2013 dev updates are always going to be frequent. i would set your update level to release based on your comments at the top of the thread.
