simjan 0 Posted October 4, 2020 Posted October 4, 2020 Hi! Chromecast doesnt work anymore with Emby. Am I alone with this problem or is it something you know about? When can we expect a fix? It connects fine but when I try to play something it just keeps loading indefinately. Certs are in place and it has been working nicely earlier. It also works fine with other streaming services, just seems to be Emby thats not working. Regards
Maisy 37 Posted October 4, 2020 Posted October 4, 2020 I just played an episode of The Blacklist from my PC Browser to Chromecast Ultra - Video with subs showing fine. Emby Server 4.5.1.0
Luke 42208 Posted October 4, 2020 Posted October 4, 2020 Hi there @simjan what kind of certificate are you using? You need to be using a certificate that the Chromecast device will trust. If it doesn't trust it, there's no way for us to force it.
simjan 0 Posted October 4, 2020 Author Posted October 4, 2020 (edited) Hi again! Its a Lets encryptcert and its worked before so I find it unprobable that should be the cause. The cert is valid. Just trying to figure out where to begin if its Emby or something else... Running 4.5.1.0 Edited October 4, 2020 by simjan
Luke 42208 Posted October 4, 2020 Posted October 4, 2020 It could very well be actually. Did you see this? https://letsencrypt.org/docs/certificate-compatibility/
Luke 42208 Posted October 4, 2020 Posted October 4, 2020 I would try as a test to remove https from your server, then restart everything and see how that compares.
simjan 0 Posted October 5, 2020 Author Posted October 5, 2020 Hi Luke! Thanks, after some more testing i more and more think its somthing with the cert but I cannot really figure out what. It doesnt matter which browser I use or if I use the Emby app on Android from external wan, it just gets stuck on loading the stream. Renewed the cert but no difference. Also updated my TLS options in HAproxy but no change. I also ran a complete ssllabs test on my domain but as far as I can tell everything seems to be ok. The DST Root CA X3 is in the chain as the article mentioned. I will try your suggestion to remove https... and see what happens.
simjan 0 Posted October 7, 2020 Author Posted October 7, 2020 Any news on this. I´m seeing others reporting the same issues, ie infinite loading circle... There is nothing more I can think of to try except going back to older version. When I removed https nothing really changed. Same problem remains. Since this started without any changes on my end I do believe it is related to one of the Emby updates. Can I download an older version somewhere? I´d like to try if that works.
Luke 42208 Posted October 15, 2020 Posted October 15, 2020 Hi there, if you're still seeing this issue, can you please try again? I've just pushed an update to our Chromecast receiver to resolve a similar issue, so it may resolve yours if it's the same thing. Thanks !
simjan 0 Posted October 19, 2020 Author Posted October 19, 2020 (edited) Hi Luke! Just checked if there was any news on this, saw this and tried to cast again. And it works! Great! But, what is this Chromecast reciever you are talking about? After a second test I noticed Emby doesnt update what I am playing, ie if I played something and then changed it still sticks to the first movie. Dont know if its relevant but thought I would mention it. Regards S Edited October 19, 2020 by simjan
Luke 42208 Posted October 19, 2020 Posted October 19, 2020 Chromecast receiver is your Chromecast device.
