AmericanCrisis 28 Posted February 19, 2016 Posted February 19, 2016 Now that Android is getting popular, we should look into getting the Repo installable via http - I see other popular repos do this.. @@Angelblue05 - take a look at this: http://www.htpcbeginner.com/install-superrepo-kodi-easy-addon-installation/ If we can get a nice short url, we could install directly from the server instead of having to download on a PC, install ESFileExplorer etc. This would be very cool! Other, lesser known apps are doing this. Quick question to anybody that can help.... How does Kodi update Emby plugin? Do I need to manually do this by downloading the new repo?
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 (edited) Install the repository of your choice. If you want to use the stable version of the Emby add-on, then install the stable repository, which contains the stable Emby add-on. If you want to be a bit more bleeding edge, you can grab the beta repository which contains the beta version of the emby add-on. Once you have the repository installed and the add-on, if we update the add-on, Kodi will see it and update according to your settings (you can set up auto-update settings by going to Kodi settings > add-ons > side menu) You can find both repo and more info here: https://github.com/MediaBrowser/plugin.video.emby/wiki Edited February 19, 2016 by Angelblue05
bluemonkey07 590 Posted February 19, 2016 Posted February 19, 2016 I would suggest turning auto updates off if you decide to use the beta repo , auto updating stable should be ok 1
rcarteraz 12 Posted March 9, 2016 Posted March 9, 2016 I'm using it on Fire Tv (android) and it is by far the greatest thing I've come across since I started using Kodi a year ago. 2
DarkStaff 1 Posted March 11, 2016 Posted March 11, 2016 (edited) Currently running Emby for Kodi on an OpenElec box (CuBoxi), have Emby Server running on Windows Vista (Old school), and library stored on a Norco RPC-4220 (16TB currently, 32TB next month) running FreeNAS. Eventually looking at a 6th Gen i5 intel NUC running Windows 7 Pro to replace current server. Edited March 11, 2016 by DarkStaff
kayoemby 2 Posted March 15, 2016 Posted March 15, 2016 Currently running Emby for Kodi on an OpenElec box (CuBoxi), have Emby Server running on Windows Vista (Old school), and library stored on a Norco RPC-4220 (16TB currently, 32TB next month) running FreeNAS. Eventually looking at a 6th Gen i5 intel NUC running Windows 7 Pro to replace current server. Just curious. Why Windows 7 pro? I'm running emby server on Windows 10 pro which also doubles as my file server. It's been flawless. I'm running Kodi on Fire Tv with the Emby addon. Again, just curiosity on my part.
bluemonkey07 590 Posted March 15, 2016 Posted March 15, 2016 Or even why not use the freenas plugin directly on your norco?
tonytoronto 1 Posted February 11, 2017 Posted February 11, 2017 Just recently i started using Emby from within Kodi. Using one laptop with windows 7 in it, also running it on my HTPC, windows 7. Recently started playing with Raspberry Pi and libreelec, but looks like Kodi V18 not supported yet, kinda sucks. Dont want to downgrade to Kripton for now.
xnappo 1611 Posted February 13, 2017 Author Posted February 13, 2017 Just recently i started using Emby from within Kodi. Using one laptop with windows 7 in it, also running it on my HTPC, windows 7. Recently started playing with Raspberry Pi and libreelec, but looks like Kodi V18 not supported yet, kinda sucks. Dont want to downgrade to Kripton for now. Pull requests welcome.
