nt-it-team 6 Posted October 3, 2020 Posted October 3, 2020 Hi all, UK based. Each multiplex has about 8-14 TV channels. Unfortunately Emby isn't (as far as I can see) able to share a tuner that is already watching a channel on that multiplex for watch or record another channel on the same multiplex. It seems to want to use another tuner through WinTV. In VLC I can create a HTTP transport stream broadcasting each channel from the multiplex on its own http port, unfortunately, VLC doesn't allow multiple adapters (a bug in the latest many versions ) Is there any other way to use the 3 Hauppauge quad tuners in Emby without WinTV? Thanks
Carlo 4561 Posted October 3, 2020 Posted October 3, 2020 Hi, At present, No to both questions (Multiplex & WinTV) but in Next Gen (next version of Emby Live TV in development) both should be a YES. The current version of Emby can share channels if people are watching or recording the same channel. For example if a person is watching CBS or BBC1 and another person watches the same station only 1 tuner should be needed. With Next Gen any station on the Multiplex will share the same tuner. Hope that helps, Carlo
nt-it-team 6 Posted October 3, 2020 Author Posted October 3, 2020 This does help - when it will be released. I'm currently testing using Cast4ME which has this, and building my own M3U file, but obviously takes a while with 122 channels! But the small test I did shows this does work. So the question (that every dev team hates!) is how long until the next version of Emby Live TV will be available, even in a beta form? I fully expect not to get a date, but a time region would be good, say roughly how many weeks/months away it is...
Carlo 4561 Posted October 3, 2020 Posted October 3, 2020 Sorry can't give a time frame. Haven't seen mention of Cast4Me in a while. Most people just use NextPVR. What made you choose Cast4Me instead?
nt-it-team 6 Posted October 3, 2020 Author Posted October 3, 2020 Simple setup, easily automated to run as a service, took about 10 minutes to setup. Has all 12 tuners connected up (3 cards) and "just works" without issue yet. Only downside is manually creating an m3u file. NextPVR I did try out, requires a "thicker" client and quite a bit more setup and bugged out in the UI while searching for channels so lost a bit of confidence there. Also for the use has alot more features than we need. 1
arrbee99 1836 Posted October 3, 2020 Posted October 3, 2020 Just as a matter of interest, which version of NextPVR did you try ? v5 I guess ?
