ebr 16338 Posted October 6, 2020 Posted October 6, 2020 Interestingly, a previous call came through just fine so it is as if something is specifically targeting this url - or maybe any url with something like "/users/" in it...? You will want to remove that APK and re-install the standard version because this one (once we figure out what is going on here) is going to be filling the logs with way too much data. Thanks.
ebr 16338 Posted October 6, 2020 Posted October 6, 2020 I've been trying to find a previous report of this but haven't been able to locate it yet. I think the solution ended up being some sort of security software on the person's router but I cannot remember exactly. I'll keep looking...
Solution Mick Media 1 Posted October 8, 2020 Solution Posted October 8, 2020 Hi I've fix it turned off the Web shield in Total AV and it picked the Emby server right away. 1
Luke 42246 Posted October 8, 2020 Posted October 8, 2020 Just now, Mick Media said: Hi I've fix it turned off the Web shield in Total AV and it picked the Emby server right away. Thanks for the feedback !
Carlo 4561 Posted October 9, 2020 Posted October 9, 2020 21 hours ago, Mick Media said: Hi I've fix it turned off the Web shield in Total AV and it picked the Emby server right away. If you don't mind me asking. Where is Total AV installed on your network? (ie router, PC, Emby Server)
Micksflick 0 Posted October 9, 2020 Author Posted October 9, 2020 It was on my PC but I have uninstalled as it due for renewal in a couple of days. Ember server is also installed on PC
