redlabs 1 Posted October 13, 2020 Posted October 13, 2020 (edited) @Lukei send you a pm Edited October 13, 2020 by redlabs
Luke 42243 Posted October 20, 2020 Posted October 20, 2020 Can you try re-downloading the beta builds and see if that helps? Thanks.
Luke 42243 Posted October 21, 2020 Posted October 21, 2020 6 hours ago, WouterC said: @Luke Nope, still core dumping. Which package did you try?
WouterC 0 Posted October 21, 2020 Author Posted October 21, 2020 @Luke This one: It is the latest one I could find in the releases channel.
Luke 42243 Posted October 21, 2020 Posted October 21, 2020 When did you last download it? Can you try downloading it again as we've patched it with some fixes. Thanks.
WouterC 0 Posted October 21, 2020 Author Posted October 21, 2020 @Luke I downloaded it from https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.0.2/emby-server-synology-mono_4.6.0.2_armv7_legacy.spk I just downloaded it again and both md5sum are the same. The Releases channel says that these files were released 18 days ago.
Luke 42243 Posted October 21, 2020 Posted October 21, 2020 Did you try installing it again? We have another user with the same model as you who is able to use the package.
WouterC 0 Posted October 22, 2020 Author Posted October 22, 2020 @Luke I uninstalled the package, rebooted the nas and installed it again: 2020-10-22T08:19:35+02:00 DiskStation synoscgi_SYNO.Core.Package.Installation_1_install[19885]: resource_api.cpp:190 Acquire service-cfg for EmbyServer when 0x0001 (done) 2020-10-22T08:19:40+02:00 DiskStation coredump: Process mono[20297] dumped core on signal [11]. 2020-10-22T08:19:51+02:00 DiskStation coredump: Process mono[21529] dumped core on signal [6]. 2020-10-22T08:19:54+02:00 DiskStation synopkg: pkgtool.cpp:3125 Package EmbyServer stops but service pkgctl-EmbyServer start 2020-10-22T08:20:19+02:00 DiskStation coredump: Process mono[23781] dumped core on signal [6]. Same result. However there is now @mono.core.gz file in /volume1. https://www.dropbox.com/s/vlva1wp8jjmcroe/%40mono.core.gz?dl=0
alucryd 318 Posted October 24, 2020 Posted October 24, 2020 @WouterC Would it be possible to get SSH access so I can run some tests? This is very strange as the same package ran fine on another DS414.
Luke 42243 Posted October 24, 2020 Posted October 24, 2020 @WouterC if yes then please start a PM with all three of us and provide the info that we'll need to connect. Thanks !
redlabs 1 Posted October 24, 2020 Posted October 24, 2020 On 10/21/2020 at 9:25 PM, Luke said: Did you try installing it again? We have another user with the same model as you who is able to use the package. yes everything is currently working wonderfully
