roshanconnor 0 Posted October 3, 2020 Posted October 3, 2020 Hi everyone So I had added my Anime Collection as a Library I chose Category - TV Shows Plugin - I installed Anime Plugin from Plugins option Database - I chose AniDB as my database of choice for the metadata My Fliles are named perfectly for Media server..its working great with Plex Server So it took some time for the initial scan and it was done after around 4 hours The issue is it detected the files..but there is no metadata at all..I cant see any images or any info about the show How can I fix this Thank you
Happy2Play 9814 Posted October 3, 2020 Posted October 3, 2020 Can you go over a specific example and provide the server log.
roshanconnor 0 Posted October 3, 2020 Author Posted October 3, 2020 19 minutes ago, Happy2Play said: Can you go over a specific example and provide the server log. Hi Thanks for responding Here is How it looks like Here are the Logs : https://del.dog/raw/pukimoweki
Happy2Play 9814 Posted October 3, 2020 Posted October 3, 2020 A dev will have to comment more but your connection to AniDB are timing out. 2020-10-03 00:01:27.536 Error App: Error in AniDB *** Error Report *** Version: 4.5.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-1024-gcp (buildd@lcy01-amd64-025) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #24~18.04.1-Ubuntu SMP Sun Sep 6 03:37:03 UTC Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.WebException: System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result) at System.Net.WebClient.<>c__DisplayClass164_0.<OpenReadAsync>b__0(IAsyncResult iar) --- End of stack trace from previous location where exception was thrown --- at MediaBrowser.Plugins.Anime.Providers.AniDB.Identity.AniDbTitleDownloader.DownloadTitles_static(String titlesFile, CancellationToken cancellationToken) at MediaBrowser.Plugins.Anime.Providers.AniDB.Identity.AniDbTitleDownloader.Load_static(CancellationToken cancellationToken) at MediaBrowser.Plugins.Anime.Providers.Equals_check.Fast_xml_search(String a, String b, CancellationToken cancellationToken, Boolean return_AniDBid, Int32 x_) at MediaBrowser.Plugins.Anime.Providers.AniDB.Metadata.AniDbSeriesProvider.GetMetadata(SeriesInfo info, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Net.Requests TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult)
roshanconnor 0 Posted October 3, 2020 Author Posted October 3, 2020 3 minutes ago, Happy2Play said: A dev will have to comment more but your connection to AniDB are timing out. 2020-10-03 00:01:27.536 Error App: Error in AniDB *** Error Report *** Version: 4.5.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-1024-gcp (buildd@lcy01-amd64-025) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #24~18.04.1-Ubuntu SMP Sun Sep 6 03:37:03 UTC Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.WebException: System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result) at System.Net.WebClient.<>c__DisplayClass164_0.<OpenReadAsync>b__0(IAsyncResult iar) --- End of stack trace from previous location where exception was thrown --- at MediaBrowser.Plugins.Anime.Providers.AniDB.Identity.AniDbTitleDownloader.DownloadTitles_static(String titlesFile, CancellationToken cancellationToken) at MediaBrowser.Plugins.Anime.Providers.AniDB.Identity.AniDbTitleDownloader.Load_static(CancellationToken cancellationToken) at MediaBrowser.Plugins.Anime.Providers.Equals_check.Fast_xml_search(String a, String b, CancellationToken cancellationToken, Boolean return_AniDBid, Int32 x_) at MediaBrowser.Plugins.Anime.Providers.AniDB.Metadata.AniDbSeriesProvider.GetMetadata(SeriesInfo info, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Net.Requests TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult) I See I hope any dev will respond to this Matter..I will wait Thanks
roshanconnor 0 Posted October 3, 2020 Author Posted October 3, 2020 1 hour ago, Luke said: Is there a problem with the anidb website? Just tested and it works fine Do you guys have any other suggestion? to use for anime?
Luke 42246 Posted October 3, 2020 Posted October 3, 2020 Perhaps you have something blocking emby server from sending the outgoing communication? Please attach the emby server log. thanks.
roshanconnor 0 Posted October 3, 2020 Author Posted October 3, 2020 (edited) Here are the logs https://del.dog/raw/pukimoweki Edited October 3, 2020 by roshanconnor
Luke 42246 Posted October 4, 2020 Posted October 4, 2020 Ok yea that log suggests to me that something in your environment is blocking the server from making a connection to anidb. The other possibility is that the connection is just slow and the timeout used by the plugin is too aggressive.
roshanconnor 0 Posted October 4, 2020 Author Posted October 4, 2020 7 minutes ago, Luke said: Ok yea that log suggests to me that something in your environment is blocking the server from making a connection to anidb. The other possibility is that the connection is just slow and the timeout used by the plugin is too aggressive. Oh I mean the connection is fast enough..1Gbps Maybe something else is blocking it Is there any other Plugin I could use for Anime? Thanks
