sirmiketr 5 Posted October 3, 2020 Posted October 3, 2020 (edited) Hopefully it hasn't been asked, can't find anything in the docs Basically, I'm at home, I'm playing an episode on my Xbox and it shows as transcoding to h264 format. Does the transcoded file get saved in a cache on the Xbox so my server doesn't have to transcode it again or is it cached on the server or it has to transcode all over again every time my Xbox plays that same episode? Edited October 3, 2020 by sirmiketr
ebr 16310 Posted October 3, 2020 Posted October 3, 2020 Hi. Transcoding is done in real-time and is not cached anywhere. This happens on the server. Does this answer your question? 1
sirmiketr 5 Posted October 3, 2020 Author Posted October 3, 2020 I think so. This means that if I finish an episode and I decide to replay that episode, it'll be transcoding again correct?
Luke 42210 Posted October 3, 2020 Posted October 3, 2020 On the same device, yes. On a different device it may not need to transcode. 1
ebr 16310 Posted October 3, 2020 Posted October 3, 2020 Hi. Also, if you know you have devices that need different formats for your media, you can use our convert feature to create versions for them that will not need to transcode. Convert Media 1
sirmiketr 5 Posted October 3, 2020 Author Posted October 3, 2020 Okay makes sense, best practice is to avoid transcoding when possible right? 1
ebr 16310 Posted October 3, 2020 Posted October 3, 2020 1 minute ago, sirmiketr said: Okay makes sense, best practice is to avoid transcoding when possible right? Not necessarily. That's one of the benefits to having a server. It can convert your media to whatever format is needed on the fly. 1
sirmiketr 5 Posted October 3, 2020 Author Posted October 3, 2020 I see! Thank you for your answers, Sirs.
