HTTPS for remote access
Hi guys,
I've done lots of reading but still a little confused. Is anyone able to direct with setting up HTTPS so I can access emby from my Android when away from home?
I have a hostname, xxxxxx.ddns.net, which I can use instead of an IP to access my network from outside. This is configured in my router.
I want to enable HTTPS so I can connect to xxxxxx.ddns.net:8920 and then via a port forwarding entry, that should let me access emby.
Now, will that work or do I need to do something with a certificate? Because I also see a box for "External Domain" in Network, but I have no idea how that comes into play with my xxxxxx.ddns.net, if I was to paste it there? Will my method also be secure if its possible to work that way without certificate?
EDIT: No idea how to make the cert for my NOIP xxxxx.ddns.net Domain Name!?
Edited by DJX
I'd like to update this post incase it helps anyone else:
Requirement: I have a free ddns.net (NOIP) hostname and I wanted to enable remote connection to Emby via HTTPS using the xxxx.ddns.net hostname. This requires certificate to be used in Emby configuration.
Step 1: Opened up port 80/443 on my Synology NAS (firewall and router with port forwarding)
Step2: Used Control Panel in Synology to create a certificate using LetsEncrypt method.
Step3: Closed port 80/443
Step4: Downloaded the certificate from DSM and put in my relevant /volume1 directory.
Step5: Converted LetsEncrypt files to PKCS#12 for Emby using openssl command as here:
Step6: Did the relevant setup in Emby for remote connection and browsed for the PKCS#12 certificate (External domain as my xxxxx.ddns.net)
Step7: Did port forwarding in my router to point my custom port to Emby HTTPS defined port. Did relevant firewall entry in Synology to allow traffic using HTTPS port.
Step8: Did relevant User setup as per my requirements
Step9: Opened Android app and connected with https://xxxxx.ddns.net:[ForwardedPort]
Edited by DJX
Hi, that's great, thanks for sharing !
