levander 97 Posted October 3, 2020 Author Posted October 3, 2020 59 minutes ago, Happy2Play said: Was just going to say I had no issue with that template using TMM, but will assume some minor space errors when pasted on forum. Must be a OS specific issue with the code ( \\ vs / ), but glad you figured it out. I'm glad too. Such banal thing but unfortunately not once I experienced something just stops working in emby as collateral damage. So I got worried that this might be similar scenario.
Happy2Play 9802 Posted October 3, 2020 Posted October 3, 2020 (edited) 2 minutes ago, levander said: I'm glad too. Such banal thing but unfortunately not once I experienced something just stops working in emby as collateral damage. So I got worried that this might be similar scenario. Basically the issue was how the item path is written within the xml, correct? Edited October 3, 2020 by Happy2Play
Solution levander 97 Posted October 3, 2020 Author Solution Posted October 3, 2020 2 minutes ago, Happy2Play said: Basically the issue was how the item path is written within the xml, correct? I would say so now, yes, but I can't be 100% sure because before I "cleaned" data/collection folder and those "residues" I haven't been able to make collection manually. Now I can't be sure why - was it some other mistake I wasn't aware of (I used copied paths from finder so paths were not the issue in that case) or something with database.
