sundevil67 30 Posted October 2, 2020 Posted October 2, 2020 I moved my Mac Mini running Emby Server to a new location for a couple of months this summer. Everything worked fine at the temporary location. I've returned home & set everything back up, and Emby is unavailable to any of my users outside my network. No changes have been made other than physically transporting the computer. They're getting server timeouts & just cannot connect. Is there any known issue that might cause this? I've looked in my router settings and just don't see anything different. Thanks for any guidance.
Luke 42241 Posted October 2, 2020 Posted October 2, 2020 Hi there, I would suggest taking a look at our connection troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
sundevil67 30 Posted October 4, 2020 Author Posted October 4, 2020 I looked around in my router settings and discovered the Emby 'service' was showing an incorrect IP address, which after correcting, seems to have resolved the problem. I'm not entirely sure how this works since I have a dynamic IP, or why/when it will change again, but don't really care as long as it works. Thanks!
sundevil67 30 Posted October 4, 2020 Author Posted October 4, 2020 On occasion I use one on my primary computer, a Macbook Pro, but just about never on the Mac Mini that runs Emby. I've already tested that use case thoroughly, and definitely couldn't get remote access working while the VPN was connected. I saw what was involved in getting that to work & decided not to bother.
Happy2Play 9811 Posted October 4, 2020 Posted October 4, 2020 Without a vpn service that allows port forwarding you will not be able to get to your server through that vpn. You could apply your true external ip in "External domain" (Dashboard-Network) but would have to manually update every time it changes if it actually does. I know I have had the same external ip for years, but every provider will be different.
