Badoune 5 Posted October 1, 2020 Posted October 1, 2020 (edited) Hi, I cannot play x265 1080p files with the following Decoded format: Planar 4:2:0 YUV 10-bit LE on my Sony Andoid TV... I get green lines or shifted images... Those same movies works using VLC on the same TV. Movies that are using this Decoded format: Planar 4:2:0 YUV works flawlessly... would it be possible to get an update that fix this issue? Thanks a lot for your help! Edited October 1, 2020 by Badoune
vdatanet 1619 Posted October 1, 2020 Posted October 1, 2020 (edited) Is it remuxing? Edited October 1, 2020 by vdatanet
vdatanet 1619 Posted October 1, 2020 Posted October 1, 2020 (edited) Although we need more information, Maybe related to this? No, It seems a transcoding problem Edited October 1, 2020 by vdatanet
vdatanet 1619 Posted October 1, 2020 Posted October 1, 2020 3 hours ago, Badoune said: Hi, I cannot play x265 1080p files with the following Decoded format: Planar 4:2:0 YUV 10-bit LE on my Sony Andoid TV... I get green lines or shifted images... Those same movies works using VLC on the same TV. Movies that are using this Decoded format: Planar 4:2:0 YUV works flawlessly... would it be possible to get an update that fix this issue? Thanks a lot for your help! Can you share a sample?
Badoune 5 Posted October 1, 2020 Author Posted October 1, 2020 (edited) Here is the log: When I set the quality to 2mb, it works... but not watchable...3mb+ the problem starts... The movies are played on a wired network. >> ThrottleBySegmentRequest: Initialize - TargetBufferSize: 120s 2020-09-30 22:55:34.535 Operating System: Microsoft Windows 10.0.19041 OS/Process: x64/x64 Emby Server version: 4.5.1.0 Operating system: Microsoft Windows NT 6.2.9200.0 Command Line: C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp App: Emby Web 4.5.1.0 Firefox c0bb7c2a6025&MediaSourceId=75ac6418e038e591a01bd1069767e33d&PlaySessionId=0a8eb08cf50648e18568c2da5cedeab1&api_key=66b5473eb7894c8a846b6179824ec5b6&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139776000&AudioBitrate=224000&AudioStreamIndex=1&SubtitleMethod=Encode&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=VideoCodecNotSupported {"Protocol":"File","Id":"75ac6418e038e591a01bd1069767e33d","Path":"I:\\EMBY\\1965 - The This Movie 1080p x265.mp4","Type":"Default","Container":"mp4","Size":2677520882,"Name":"1965 - The Great Race 1080p x265","IsRemote":false,"RunTimeTicks":95980680000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","CodecTag":"hev1","Language":"und","TimeBase":"1/24000","CodecTimeBase":"1001/24000","VideoRange":"SDR","DisplayTitle":"1080p HEVC","IsInterlaced":false,"BitRate":2001061,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":796,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":"Video","AspectRatio":"480:199","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"aac","CodecTag":"mp4a","Language":"eng","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"English AAC 5.1 (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":224000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":2231716,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for TRAERTA EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder libx264 Software Encoder Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Custom Info Checking: 'libx264 Software Encoder' Info Check successful - selecting 'libx264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Custom Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info ColorConversion >> False False Info VideoOutput >> False False Not a hardware encoder Info libx264 Software Encoder >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Next Info hevc >> - yuv420p10 yuv420p10 >> format Info format >> - yuv420p yuv420p >> >>>>> Non-Default Encoder Parameters Warning EncoderParametersH264LibX.ConstantRateFactor: Original: 23 Actual: 24 C:\Users\TRAERTA\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-a08c84bb-6275-496c-9ca4-a53a59fa71cd_1graph.txt" -copyts -start_at_zero -f mp4 -c:v:0 hevc -i "I:\EMBY\1965 - The This Movie 1080p x265.mp4" -filter_complex "[0:0]format@f1=pix_fmts=yuv420p[f1_out0]" -map [f1_out0] -map 0:1 -sn -c:v:0 libx264 -g:v:0 72 -maxrate:v:0 4002122 -bufsize:v:0 8004244 -sc_threshold:v:0 0 -keyint_min:v:0 72 -pix_fmt:v:0 yuv420p -preset:v:0 veryfast -profile:v:0 high -level:v:0 4.0 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:partitions=none" -crf:v:0 24 -c:a:0 copy -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_%d.ts" 22:55:35.003 ffmpeg version 4.3.0-emby_2020_05_23-g8f222573e9+530 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC 22:55:35.003 built with gcc 9.2.0 (Rev2, Built by MSYS2 project) 22:55:35.003 Execution Date: 2020-09-30 22:55:35 22:55:35.157 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'I:\EMBY\1965 - The This Movie 1080p x265.mp4': 22:55:35.158 Metadata: 22:55:35.158 major_brand : isom 22:55:35.158 minor_version : 512 22:55:35.158 compatible_brands: isomiso2mp41 22:55:35.158 creation_time : 2020-07-30T04:36:33.000000Z 22:55:35.158 title : The.This.Movie.1965.1080p.BluRay.x265-RARBG 22:55:35.158 encoder : Lavf58.20.100 22:55:35.158 comment : The.This.Movie.1965.1080p.BluRay.x265-RARBG 22:55:35.158 Duration: 02:39:58.07, start: 0.000000, bitrate: 2231 kb/s 22:55:35.158 Stream #0:0(und): Video: hevc (Main 10) (hev1 / 0x31766568), yuv420p10le(tv), 1920x796 [SAR 1:1 DAR 480:199], 2001 kb/s, Level 120, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default) 22:55:35.158 Metadata: 22:55:35.158 creation_time : 2020-07-30T04:36:33.000000Z 22:55:35.158 handler_name : VideoHandler 22:55:35.158 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 224 kb/s (default) 22:55:35.158 Metadata: 22:55:35.158 creation_time : 2020-07-30T04:36:33.000000Z 22:55:35.158 handler_name : SoundHandler 22:55:35.167 Stream mapping: 22:55:35.167 Stream #0:0 (hevc) -> format 22:55:35.167 format -> Stream #0:0 (libx264) 22:55:35.167 Stream #0:1 -> #0:1 (copy) 22:55:35.167 Press [q] to stop, [?] for help 22:55:35.203 [libx264 @ 0000027229969180] using SAR=1/1 22:55:35.207 [libx264 @ 0000027229969180] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 22:55:35.210 [libx264 @ 0000027229969180] profile High, level 4.0, 4:2:0, 8-bit 22:55:35.211 [libx264 @ 0000027229969180] 264 - core 159 r2991 1771b55 - H.264/MPEG-4 AVC codec - Copyleft 2003-2019 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=72 keyint_min=37 scenecut=0 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=24.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=4002 vbv_bufsize=8004 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 22:55:35.212 Output #0, segment, to 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_%d.ts': 22:55:35.212 Metadata: 22:55:35.212 encoder : Lavf58.35.100 22:55:35.212 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x796 [SAR 1:1 DAR 480:199], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) 22:55:35.212 Metadata: 22:55:35.212 encoder : Lavc58.62.100 libx264 22:55:35.212 Side data: 22:55:35.212 cpb: bitrate max/min/avg: 4002000/0/0 buffer size: 8004000 vbv_delay: N/A 22:55:35.212 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 224 kb/s (default) 22:55:35.599 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:35.627 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=3908E9_0.ts 22:55:35.627 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_1.ts.tmp' for writing 22:55:35.668 frame= 110 fps=0.0 q=29.0 size= 405kB time=00:00:04.88 bitrate=N/A throttle=off speed= 0x 22:55:35.917 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:35.940 SegmentComplete=video:0 Index=1 Start=3.003000 End=6.006000 Duration=3.003000 offset_pts=0 start_pts=3003000 Frames=72 filename=3908E9_1.ts 22:55:35.940 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_2.ts.tmp' for writing 22:55:36.170 frame= 229 fps=228 q=29.0 size= 712kB time=00:00:09.85 bitrate=1173.4kbits/s throttle=off speed=4.96x 22:55:36.221 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:36.231 SegmentComplete=video:0 Index=2 Start=6.006000 End=9.009000 Duration=3.003000 offset_pts=0 start_pts=6006000 Frames=72 filename=3908E9_2.ts 22:55:36.231 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_3.ts.tmp' for writing 22:55:36.482 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:36.490 SegmentComplete=video:0 Index=3 Start=9.009000 End=12.012000 Duration=3.003000 offset_pts=0 start_pts=9009000 Frames=72 filename=3908E9_3.ts 22:55:36.490 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_4.ts.tmp' for writing 22:55:36.674 frame= 367 fps=244 q=29.0 size= 1075kB time=00:00:15.61 bitrate= 820.3kbits/s throttle=off speed=7.12x 22:55:36.748 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:36.758 SegmentComplete=video:0 Index=4 Start=12.012000 End=15.015000 Duration=3.003000 offset_pts=0 start_pts=12012000 Frames=72 filename=3908E9_4.ts 22:55:36.758 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_5.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:00:15 - TranscodingPosition: 00:00:15 - ThrottleBuffer: 1s (Treshold: 120s) 22:55:37.035 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:37.045 SegmentComplete=video:0 Index=5 Start=15.015000 End=18.018000 Duration=3.003000 offset_pts=0 start_pts=15015000 Frames=72 filename=3908E9_5.ts 22:55:37.045 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_6.ts.tmp' for writing 22:55:37.175 frame= 492 fps=245 q=29.0 size= 1410kB time=00:00:20.82 bitrate= 724.7kbits/s throttle=off speed=7.93x 22:55:37.313 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:37.322 SegmentComplete=video:0 Index=6 Start=18.018000 End=21.021000 Duration=3.003000 offset_pts=0 start_pts=18018000 Frames=72 filename=3908E9_6.ts 22:55:37.322 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_7.ts.tmp' for writing 22:55:37.573 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:37.585 SegmentComplete=video:0 Index=7 Start=21.021000 End=24.024000 Duration=3.003000 offset_pts=0 start_pts=21021000 Frames=72 filename=3908E9_7.ts 22:55:37.586 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_8.ts.tmp' for writing 22:55:37.678 frame= 628 fps=250 q=29.0 size= 1773kB time=00:00:26.49 bitrate= 672.3kbits/s throttle=off speed= 8.6x 22:55:37.838 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:37.848 SegmentComplete=video:0 Index=8 Start=24.024000 End=27.027000 Duration=3.003000 offset_pts=0 start_pts=24024000 Frames=72 filename=3908E9_8.ts 22:55:37.848 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_9.ts.tmp' for writing 22:55:38.105 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:38.115 SegmentComplete=video:0 Index=9 Start=27.027000 End=30.030000 Duration=3.003000 offset_pts=0 start_pts=27027000 Frames=72 filename=3908E9_9.ts 22:55:38.115 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_10.ts.tmp' for writing 22:55:38.180 frame= 766 fps=254 q=29.0 size= 2150kB time=00:00:32.25 bitrate= 643.5kbits/s throttle=off speed=9.08x 22:55:38.371 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:38.380 SegmentComplete=video:0 Index=10 Start=30.030000 End=33.033000 Duration=3.003000 offset_pts=0 start_pts=30030000 Frames=72 filename=3908E9_10.ts 22:55:38.380 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_11.ts.tmp' for writing 22:55:38.627 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:38.636 SegmentComplete=video:0 Index=11 Start=33.033000 End=36.036000 Duration=3.003000 offset_pts=0 start_pts=33033000 Frames=72 filename=3908E9_11.ts 22:55:38.636 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_12.ts.tmp' for writing 22:55:38.682 frame= 904 fps=257 q=29.0 size= 2538kB time=00:00:38.01 bitrate= 627.4kbits/s throttle=off speed=9.43x 22:55:38.900 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:38.930 SegmentComplete=video:0 Index=12 Start=36.036000 End=39.039000 Duration=3.003000 offset_pts=0 start_pts=36036000 Frames=72 filename=3908E9_12.ts 22:55:38.930 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_13.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:00:39 - TranscodingPosition: 00:00:38 - ThrottleBuffer: -1s (Treshold: 120s) 22:55:39.184 frame= 1027 fps=256 q=29.0 size= 2822kB time=00:00:43.13 bitrate= 604.4kbits/s throttle=off speed=9.52x 22:55:39.212 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:39.223 SegmentComplete=video:0 Index=13 Start=39.039000 End=42.042000 Duration=3.003000 offset_pts=0 start_pts=39039000 Frames=72 filename=3908E9_13.ts 22:55:39.223 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_14.ts.tmp' for writing 22:55:39.476 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:39.485 SegmentComplete=video:0 Index=14 Start=42.042000 End=45.045000 Duration=3.003000 offset_pts=0 start_pts=42042000 Frames=72 filename=3908E9_14.ts 22:55:39.485 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_15.ts.tmp' for writing 22:55:39.684 frame= 1164 fps=258 q=29.0 size= 3212kB time=00:00:48.85 bitrate= 598.5kbits/s throttle=off speed=9.73x 22:55:39.734 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:39.743 SegmentComplete=video:0 Index=15 Start=45.045000 End=48.048000 Duration=3.003000 offset_pts=0 start_pts=45045000 Frames=72 filename=3908E9_15.ts 22:55:39.743 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_16.ts.tmp' for writing 22:55:39.999 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:40.007 SegmentComplete=video:0 Index=16 Start=48.048000 End=51.051000 Duration=3.003000 offset_pts=0 start_pts=48048000 Frames=72 filename=3908E9_16.ts 22:55:40.007 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_17.ts.tmp' for writing 22:55:40.185 frame= 1301 fps=259 q=29.0 size= 3611kB time=00:00:54.57 bitrate= 595.4kbits/s throttle=off speed= 9.9x 22:55:40.261 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:40.269 SegmentComplete=video:0 Index=17 Start=51.051000 End=54.054000 Duration=3.003000 offset_pts=0 start_pts=51051000 Frames=72 filename=3908E9_17.ts 22:55:40.269 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_18.ts.tmp' for writing 22:55:40.523 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:40.534 SegmentComplete=video:0 Index=18 Start=54.054000 End=57.057000 Duration=3.003000 offset_pts=0 start_pts=54054000 Frames=72 filename=3908E9_18.ts 22:55:40.534 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_19.ts.tmp' for writing 22:55:40.686 frame= 1438 fps=261 q=29.0 size= 4011kB time=00:01:00.28 bitrate= 593.1kbits/s throttle=off speed= 10x 22:55:40.794 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:40.805 SegmentComplete=video:0 Index=19 Start=57.057000 End=60.060000 Duration=3.003000 offset_pts=0 start_pts=57057000 Frames=72 filename=3908E9_19.ts 22:55:40.805 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_20.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:01:00 - TranscodingPosition: 00:01:00 - ThrottleBuffer: 0s (Treshold: 120s) 22:55:41.077 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:41.087 SegmentComplete=video:0 Index=20 Start=60.060000 End=63.063000 Duration=3.003000 offset_pts=0 start_pts=60060000 Frames=72 filename=3908E9_20.ts 22:55:41.087 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_21.ts.tmp' for writing 22:55:41.190 frame= 1566 fps=260 q=29.0 size= 4399kB time=00:01:05.62 bitrate= 593.4kbits/s throttle=off speed=10.1x 22:55:41.355 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:41.363 SegmentComplete=video:0 Index=21 Start=63.063000 End=66.066000 Duration=3.003000 offset_pts=0 start_pts=63063000 Frames=72 filename=3908E9_21.ts 22:55:41.363 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_22.ts.tmp' for writing 22:55:41.616 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:41.624 SegmentComplete=video:0 Index=22 Start=66.066000 End=69.069000 Duration=3.003000 offset_pts=0 start_pts=66066000 Frames=72 filename=3908E9_22.ts 22:55:41.624 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_23.ts.tmp' for writing 22:55:41.691 frame= 1702 fps=261 q=29.0 size= 4800kB time=00:01:11.29 bitrate= 592.1kbits/s throttle=off speed=10.2x 22:55:41.883 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:41.890 SegmentComplete=video:0 Index=23 Start=69.069000 End=72.072000 Duration=3.003000 offset_pts=0 start_pts=69069000 Frames=72 filename=3908E9_23.ts 22:55:41.890 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_24.ts.tmp' for writing 22:55:42.160 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:42.169 SegmentComplete=video:0 Index=24 Start=72.072000 End=75.075000 Duration=3.003000 offset_pts=0 start_pts=72072000 Frames=72 filename=3908E9_24.ts 22:55:42.169 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_25.ts.tmp' for writing 22:55:42.192 frame= 1834 fps=261 q=29.0 size= 5200kB time=00:01:16.79 bitrate= 592.4kbits/s throttle=off speed=10.2x 22:55:42.429 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:42.437 SegmentComplete=video:0 Index=25 Start=75.075000 End=78.078000 Duration=3.003000 offset_pts=0 start_pts=75075000 Frames=72 filename=3908E9_25.ts 22:55:42.437 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_26.ts.tmp' for writing 22:55:42.695 frame= 1970 fps=262 q=29.0 size= 5525kB time=00:01:22.47 bitrate= 583.4kbits/s throttle=off speed=10.3x 22:55:42.699 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:42.709 SegmentComplete=video:0 Index=26 Start=78.078000 End=81.081000 Duration=3.003000 offset_pts=0 start_pts=78078000 Frames=72 filename=3908E9_26.ts 22:55:42.709 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_27.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:01:21 - TranscodingPosition: 00:01:22 - ThrottleBuffer: 1s (Treshold: 120s) 22:55:42.992 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:43.001 SegmentComplete=video:0 Index=27 Start=81.081000 End=84.084000 Duration=3.003000 offset_pts=0 start_pts=81081000 Frames=72 filename=3908E9_27.ts 22:55:43.001 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_28.ts.tmp' for writing 22:55:43.197 frame= 2092 fps=261 q=29.0 size= 5907kB time=00:01:27.55 bitrate= 585.4kbits/s throttle=off speed=10.3x 22:55:43.280 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:43.287 SegmentComplete=video:0 Index=28 Start=84.084000 End=87.087000 Duration=3.003000 offset_pts=0 start_pts=84084000 Frames=72 filename=3908E9_28.ts 22:55:43.287 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_29.ts.tmp' for writing 22:55:43.540 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:43.548 SegmentComplete=video:0 Index=29 Start=87.087000 End=90.090000 Duration=3.003000 offset_pts=0 start_pts=87087000 Frames=72 filename=3908E9_29.ts 22:55:43.548 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_30.ts.tmp' for writing 22:55:43.699 frame= 2230 fps=261 q=29.0 size= 6317kB time=00:01:33.31 bitrate= 585.2kbits/s throttle=off speed=10.4x 22:55:43.803 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:43.812 SegmentComplete=video:0 Index=30 Start=90.090000 End=93.093000 Duration=3.003000 offset_pts=0 start_pts=90090000 Frames=72 filename=3908E9_30.ts 22:55:43.812 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_31.ts.tmp' for writing 22:55:44.065 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:44.074 SegmentComplete=video:0 Index=31 Start=93.093000 End=96.096000 Duration=3.003000 offset_pts=0 start_pts=93093000 Frames=72 filename=3908E9_31.ts 22:55:44.074 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_32.ts.tmp' for writing 22:55:44.202 frame= 2365 fps=262 q=29.0 size= 6722kB time=00:01:38.94 bitrate= 585.5kbits/s throttle=off speed=10.4x 22:55:44.339 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:44.347 SegmentComplete=video:0 Index=32 Start=96.096000 End=99.099000 Duration=3.003000 offset_pts=0 start_pts=96096000 Frames=72 filename=3908E9_32.ts 22:55:44.347 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_33.ts.tmp' for writing 22:55:44.599 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:44.608 SegmentComplete=video:0 Index=33 Start=99.099000 End=102.102000 Duration=3.003000 offset_pts=0 start_pts=99099000 Frames=72 filename=3908E9_33.ts 22:55:44.608 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_34.ts.tmp' for writing 22:55:44.705 frame= 2501 fps=262 q=29.0 size= 7132kB time=00:01:44.61 bitrate= 585.8kbits/s throttle=off speed=10.5x 22:55:44.878 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:44.889 SegmentComplete=video:0 Index=34 Start=102.102000 End=105.105000 Duration=3.003000 offset_pts=0 start_pts=102102000 Frames=72 filename=3908E9_34.ts 22:55:44.889 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_35.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:01:45 - TranscodingPosition: 00:01:44 - ThrottleBuffer: -0s (Treshold: 120s) 22:55:45.171 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:45.180 SegmentComplete=video:0 Index=35 Start=105.105000 End=108.108000 Duration=3.003000 offset_pts=0 start_pts=105105000 Frames=72 filename=3908E9_35.ts 22:55:45.180 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_36.ts.tmp' for writing 22:55:45.207 frame= 2627 fps=262 q=29.0 size= 7521kB time=00:01:49.86 bitrate= 586.9kbits/s throttle=off speed=10.5x 22:55:45.471 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:45.483 SegmentComplete=video:0 Index=36 Start=108.108000 End=111.111000 Duration=3.003000 offset_pts=0 start_pts=108108000 Frames=72 filename=3908E9_36.ts 22:55:45.484 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_37.ts.tmp' for writing 22:55:45.710 frame= 2752 fps=261 q=26.0 size= 7825kB time=00:01:55.09 bitrate= 581.7kbits/s throttle=off speed=10.5x 22:55:45.750 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:45.759 SegmentComplete=video:0 Index=37 Start=111.111000 End=114.114000 Duration=3.003000 offset_pts=0 start_pts=111111000 Frames=72 filename=3908E9_37.ts 22:55:45.759 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_38.ts.tmp' for writing 22:55:46.020 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:46.028 SegmentComplete=video:0 Index=38 Start=114.114000 End=117.117000 Duration=3.003000 offset_pts=0 start_pts=114114000 Frames=72 filename=3908E9_38.ts 22:55:46.028 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_39.ts.tmp' for writing 22:55:46.211 frame= 2885 fps=261 q=29.0 size= 8222kB time=00:02:00.63 bitrate= 581.9kbits/s throttle=off speed=10.5x 22:55:46.288 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:46.297 SegmentComplete=video:0 Index=39 Start=117.117000 End=120.120000 Duration=3.003000 offset_pts=0 start_pts=117117000 Frames=72 filename=3908E9_39.ts 22:55:46.297 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_40.ts.tmp' for writing 22:55:46.549 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:46.557 SegmentComplete=video:0 Index=40 Start=120.120000 End=123.123000 Duration=3.003000 offset_pts=0 start_pts=120120000 Frames=72 filename=3908E9_40.ts 22:55:46.557 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_41.ts.tmp' for writing 22:55:46.714 frame= 3021 fps=262 q=29.0 size= 8628kB time=00:02:06.31 bitrate= 582.1kbits/s throttle=off speed=10.5x 22:55:46.832 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:46.845 SegmentComplete=video:0 Index=41 Start=123.123000 End=126.126000 Duration=3.003000 offset_pts=0 start_pts=123123000 Frames=72 filename=3908E9_41.ts 22:55:46.845 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_42.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:02:06 - ThrottleBuffer: 3s (Treshold: 120s) 22:55:47.134 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:47.145 SegmentComplete=video:0 Index=42 Start=126.126000 End=129.129000 Duration=3.003000 offset_pts=0 start_pts=126126000 Frames=72 filename=3908E9_42.ts 22:55:47.145 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_43.ts.tmp' for writing 22:55:47.216 frame= 3142 fps=261 q=29.0 size= 9009kB time=00:02:11.34 bitrate= 583.6kbits/s throttle=off speed=10.5x 22:55:47.409 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:47.436 SegmentComplete=video:0 Index=43 Start=129.129000 End=132.132000 Duration=3.003000 offset_pts=0 start_pts=129129000 Frames=72 filename=3908E9_43.ts 22:55:47.436 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_44.ts.tmp' for writing 22:55:47.691 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:47.699 SegmentComplete=video:0 Index=44 Start=132.132000 End=135.135000 Duration=3.003000 offset_pts=0 start_pts=132132000 Frames=72 filename=3908E9_44.ts 22:55:47.699 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_45.ts.tmp' for writing 22:55:47.719 frame= 3273 fps=261 q=29.0 size= 9403kB time=00:02:16.81 bitrate= 583.9kbits/s throttle=off speed=10.5x 22:55:47.961 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:47.971 SegmentComplete=video:0 Index=45 Start=135.135000 End=138.138000 Duration=3.003000 offset_pts=0 start_pts=135135000 Frames=72 filename=3908E9_45.ts 22:55:47.971 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_46.ts.tmp' for writing 22:55:48.222 frame= 3407 fps=261 q=29.0 size= 9728kB time=00:02:22.39 bitrate= 579.5kbits/s throttle=off speed=10.5x 22:55:48.237 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:48.246 SegmentComplete=video:0 Index=46 Start=138.138000 End=141.141000 Duration=3.003000 offset_pts=0 start_pts=138138000 Frames=72 filename=3908E9_46.ts 22:55:48.246 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_47.ts.tmp' for writing 22:55:48.508 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:48.523 SegmentComplete=video:0 Index=47 Start=141.141000 End=144.144000 Duration=3.003000 offset_pts=0 start_pts=141141000 Frames=72 filename=3908E9_47.ts 22:55:48.523 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_48.ts.tmp' for writing 22:55:48.723 frame= 3539 fps=261 q=29.0 size= 10124kB time=00:02:27.90 bitrate= 579.9kbits/s throttle=off speed=10.6x 22:55:48.785 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:48.794 SegmentComplete=video:0 Index=48 Start=144.144000 End=147.147000 Duration=3.003000 offset_pts=0 start_pts=144144000 Frames=72 filename=3908E9_48.ts 22:55:48.794 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_49.ts.tmp' for writing >> ThrottleBySegmentRequest: RequestPosition: 00:02:03 - TranscodingPosition: 00:02:27 - ThrottleBuffer: 25s (Treshold: 120s) 22:55:49.071 [q] command received. Exiting. 22:55:49.094 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:49.105 SegmentComplete=video:0 Index=49 Start=147.147000 End=150.150000 Duration=3.003000 offset_pts=0 start_pts=147147000 Frames=72 filename=3908E9_49.ts 22:55:49.105 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9_50.ts.tmp' for writing 22:55:49.116 22:55:49.116 [segment @ 0000027229940540] Opening 'C:\Users\TRAERTA\AppData\Roaming\Emby-Server\programdata\transcoding-temp\3908E9.m3u8.tmp' for writing 22:55:49.126 SegmentComplete=video:0 Index=50 Start=150.150000 End=150.859044 Duration=0.709044 offset_pts=0 start_pts=150150000 Frames=17 filename=3908E9_50.ts 22:55:49.126 frame= 3617 fps=259 q=-1.0 Lsize= 10441kB time=00:02:31.14 bitrate= 584.8kbits/s throttle=off speed=10.5x 22:55:49.126 video:6304kB audio:4136kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000% Last message repeated 1 times 22:55:49.135 EXIT 22:55:49.143 [libx264 @ 0000027229969180] frame I:51 Avg QP:15.57 size: 80647 22:55:49.143 [libx264 @ 0000027229969180] frame P:934 Avg QP:15.90 size: 1144 22:55:49.143 [libx264 @ 0000027229969180] frame B:2632 Avg QP:18.29 size: 484 22:55:49.143 [libx264 @ 0000027229969180] consecutive B-frames: 2.1% 1.4% 3.7% 92.8% 22:55:49.143 [libx264 @ 0000027229969180] mb I I16..4: 68.4% 11.0% 20.6% 22:55:49.143 [libx264 @ 0000027229969180] mb P I16..4: 15.7% 0.0% 0.0% P16..4: 7.3% 0.0% 0.0% 0.0% 0.0% skip:76.9% 22:55:49.143 [libx264 @ 0000027229969180] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct:11.4% skip:88.6% L0:86.8% L1:12.4% BI: 0.8% 22:55:49.143 [libx264 @ 0000027229969180] 8x8 transform intra:2.8% inter:60.1% 22:55:49.143 [libx264 @ 0000027229969180] coded y,uvDC,uvAC intra: 8.9% 13.2% 8.7% inter: 0.1% 10.7% 0.0% 22:55:49.143 [libx264 @ 0000027229969180] i16 v,h,dc,p: 97% 2% 1% 0% 22:55:49.143 [libx264 @ 0000027229969180] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 15% 32% 8% 6% 4% 6% 4% 5% 22:55:49.143 [libx264 @ 0000027229969180] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 23% 8% 6% 6% 7% 6% 6% 8% 22:55:49.143 [libx264 @ 0000027229969180] i8c dc,h,v,p: 63% 28% 8% 1% 22:55:49.143 [libx264 @ 0000027229969180] Weighted P-Frames: Y:2.8% UV:2.1% 22:55:49.143 [libx264 @ 0000027229969180] kb/s:342.30 22:55:49.161 ======= ExtraData 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 Edited October 1, 2020 by Badoune
ebr 16338 Posted October 1, 2020 Posted October 1, 2020 6 hours ago, Badoune said: When I set the quality to 2mb, it works... but not watchable...3mb+ the problem starts... That would indicate the TV doesn't support that format. As the content is slightly over 2Mb/s, setting the limit there causes a transcode. It looks like the log you provided above is from when it works, correct? Using the "Playback Correction" option in the app should achieve the same result without having to change your bitrate setting. I'm not sure exactly what about the video isn't supported properly by the TV though.
Badoune 5 Posted October 1, 2020 Author Posted October 1, 2020 VLC play that format perfectly on the TV so I guess the TV is capable of playing that format. And no that log was from the screen shots ''OVERTURE'' with the green line on top and jerkiness in the picture...I have 100+ movies with Decoded format: Planar 4:2:0 YUV 10-bit LE and they all behave differently but none of them works correctly as compare to the other 100+ movies Planar 4:2:0 YUV that all works perfect...
ebr 16338 Posted October 2, 2020 Posted October 2, 2020 17 hours ago, Badoune said: VLC play that format perfectly on the TV so I guess the TV is capable of playing that format. VLC has ffmpeg embedded in it so using it is roughly equivalent to what happens when our server transcodes it for you (which also works). Can you please show us the media info from the bottom of the detail page in the web app for one of the problem items? Thanks.
Badoune 5 Posted October 3, 2020 Author Posted October 3, 2020 Media Info Video Title1080p HEVC CodecHEVC Codec Taghev1 ProfileMain 10 Level120 Resolution1920x796 Aspect Ratio480:199 AnamorphicNo InterlacedNo Framerate23.976 Bitrate2,001 kbps Bit Depth10 bit Pixel Formatyuv420p10le Reference Frames1 Audio TitleEnglish AAC 5.1 (Default) LanguageEnglish CodecAAC Codec Tagmp4a ProfileLC Layout5.1 Channels6 ch Bitrate224 kbps Sample Rate48,000 Hz DefaultYes Containermp4 PathI:\EMBY\1965 - The Great Race 1080p x265.mp4 Size2553MB
ebr 16338 Posted October 3, 2020 Posted October 3, 2020 Now, can you please play that exact same item for just a few seconds (until problems occur) and then immediately send a log from the app? Thanks.
ebr 16338 Posted October 5, 2020 Posted October 5, 2020 Hi. Thanks for the log. Unfortunately, I don't think it really reveals anything. The types of artifacts you describe are commonly seen with poor hardware accelerated decoders sometimes. In this case, they may be in the TV itself (which is a relatively old 2015 model). If there are any firmware updates for the TV I would definitely apply those. Other than that, I'm not sure what else to try other than possibly a re-encode of the item or just using playback correction to force transcoding for it.
Badoune 5 Posted October 5, 2020 Author Posted October 5, 2020 The original video player that comes with the TV play the file flawlessly, same for vlc like I mention before...
ebr 16338 Posted October 5, 2020 Posted October 5, 2020 1 minute ago, Badoune said: same for vlc like I mention before Yes, VLC is using ffmpeg to decode it just like we will if you force a transcode. It could be a deficiency in Android or Exoplayer possibly... Can you get me a sample of this media?
