Nyder 1 Posted September 30, 2020 Posted September 30, 2020 Hi, I recently upgraded to Emby Premier so I could stream 4k/HDR/ATMOS to my Sony Android TV. The TV is hooked up to a sound bar via EARC which Supports both EARC/4K passthrough and DTS-HD/Atmos/DTSX etc. I have all the pass through settings enabled in the app and on the tv. When I play a file which normally displays ATMOS on my soundbar when I play from HTPC I only seem to be getting TRUEHD 7.1 via the Emby for android tv app. Is ATMOS supported for Emby for android tv? is there a server setting I need to enable? Nyd
ebr 16354 Posted October 1, 2020 Posted October 1, 2020 Atmos is supported if all of the hardware supports it. I just tested this myself recently. Why do you say you "only seem to be getting"?
Nyder 1 Posted October 1, 2020 Author Posted October 1, 2020 (edited) 45 minutes ago, ebr said: Atmos is supported if all of the hardware supports it. I just tested this myself recently. Why do you say you "only seem to be getting"? Figured it out, Sony apps don't support lossless audio, everything works via Emby theatre for Windows Thanks, Nyd Edited October 1, 2020 by Nyder
Dariusz 25 Posted October 2, 2020 Posted October 2, 2020 On 9/30/2020 at 6:45 PM, Nyder said: Hi, I recently upgraded to Emby Premier so I could stream 4k/HDR/ATMOS to my Sony Android TV. The TV is hooked up to a sound bar via EARC which Supports both EARC/4K passthrough and DTS-HD/Atmos/DTSX etc. I have all the pass through settings enabled in the app and on the tv. When I play a file which normally displays ATMOS on my soundbar when I play from HTPC I only seem to be getting TRUEHD 7.1 via the Emby for android tv app. Is ATMOS supported for Emby for android tv? is there a server setting I need to enable? Nyd which sony TV do you have? I believe sony will release a firmware update in near future for 2020 TVs which enables eARC on the ports as well as HDMI 2.1, until then, these TVs should only be passing ARC and HDMI 2.0.. so ARC will not pass uncompressed signals until then to my knowledge..
Nyder 1 Posted October 2, 2020 Author Posted October 2, 2020 I have a Sony A8H. It already does support EARC, and it works fine. Sony Smart TV Apps don't pass lossless audio via passthrough/EARC or otherwise. Since my source file was ATMOS-TRUEHD=Lossless it didn't get passed by the Emby for android TV app. When I use Emby Theater on windows 10, the Lossless audio passes through just fine via EARC and I got Dolby Atmos. Apparently issue is on all smart TV's LG etc. So solution is use Home Theater PC or Nvidia Shield, or other dedicated media streaming device. Nyd
ebr 16354 Posted October 2, 2020 Posted October 2, 2020 Correct. The only Android device I'm aware of that will pass TrueHD or DTS-HD is the Shield.
sbarmen 0 Posted March 24 Posted March 24 I wonder about this if it still the case. I have a Sony TV with Google TV. If I run Netflix or Apple TV for example I get Atmos sound, but not with Emby. My TV is a Sony XR-77A80J (https://www.sony.com/electronics/support/televisions-projectors-oled-tvs-android-/xr-77a80j/specifications). Am I doing something wrong?
FrostByte 5464 Posted March 24 Posted March 24 (edited) 1 hour ago, sbarmen said: I wonder about this if it still the case. I have a Sony TV with Google TV. If I run Netflix or Apple TV for example I get Atmos sound, but not with Emby. My TV is a Sony XR-77A80J (https://www.sony.com/electronics/support/televisions-projectors-oled-tvs-android-/xr-77a80j/specifications). Am I doing something wrong? Netflix and AppleTV use DD+ Atmos not TrueHD Atmos. The Emby app should pass DD+ Atmos also. As far as I know Sony apps still don't passthrough TrueHD. However, if you want to test this out turn off audio transcoding on the server. This will tell Emby to just pass the audio untouched and let the hardware try and handle it. Edit: if you try turning off audio transcoding make sure it's actually coming out as TrueHD and triggering Atmos. Some devices will auto convert using hardware to something like PCM 2.0 Edited March 24 by FrostByte 2 2
yocker 1431 Posted March 24 Posted March 24 Got a Sony from around that time my self and as FrostByte says you will only get Atmos with eac3 formats. If you want all sound formats you will need an external player like for example a Nvidia Shield. 2
sbarmen 0 Posted March 25 Posted March 25 Ok, so if a source has TrueHD or proper Atmos soundtrack that could not be transcoded to Enhanced AC-3?
FrostByte 5464 Posted March 25 Posted March 25 1 hour ago, sbarmen said: Ok, so if a source has TrueHD or proper Atmos soundtrack that could not be transcoded to Enhanced AC-3? Currently AC3 384kbps is the only thing Emby will transcode to. There is a feature request for additional codecs such as plain EAC3 and some additional bitrate options. EAC3 with Atmos would require licensing fees. 1
sbarmen 0 Posted March 28 Posted March 28 Ah... That's a shame. It would be the best option to strike the best balance. Thanks for clarifying!
yocker 1431 Posted March 28 Posted March 28 On 3/25/2026 at 10:58 AM, FrostByte said: Currently AC3 384kbps is the only thing Emby will transcode to. There is a feature request for additional codecs such as plain EAC3 and some additional bitrate options. EAC3 with Atmos would require licensing fees. You mean it's the "highest" it will transcode to, correct? I often see sound being transcoded to MP3 and AAC. 1
FrostByte 5464 Posted March 28 Posted March 28 3 minutes ago, yocker said: You mean it's the "highest" it will transcode to, correct? I often see sound being transcoded to MP3 and AAC. Correct. I guess the only audio codecs I have that need transcoding on my Samsung TV are DTS and TrueHD so I never see anything else and I have none which need transcoding on my Shield 1
