bakes82 167 Posted September 30, 2020 Posted September 30, 2020 When running the the "try now" endpoints from the swagger UI, the code appears to be using the local ip instead of the public ip. When you run this behind a reverse proxy you cant access the local ports. But if you copy the command and run it via postman/browser and remove/update the :8096 port to the public port it works fine.
Luke 42238 Posted September 30, 2020 Posted September 30, 2020 It should be using whatever address you came in from with the web app.
bakes82 167 Posted September 30, 2020 Author Posted September 30, 2020 It looks like this and the port 8096 appears in the server dropdown box
